gauge clusters
i looked theru some of the history from the site,wondering who makes guage clusters (analog type) for our trucks.i have the factory tach,oil pressure,ammeter,speedo,water temp,
i saw dakota digital but not really my style,my truck is a daily driver so any change out i do has be something that takes less than a weekend,i want to reuse the factory harness if possible. thanks in advance
'69cst/10 |
#2 | |||
Union Electrician
Re: gauge clusters
I restore factory dash clusters.
Here is a link to one on mine on ebay, look at my other items as there are a few for sale this week, all the ones I sell are direct plug and play easy to install in about 1/2 hour Here is the link> http://cgi.ebay.com/ebaymotors/ws/eB...7424595&rd=1,1 They are availible in red,white,blue, silver, yellow, and stock black.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Re: gauge clusters
Byrd`s the "Clusterminator".
#4 | |||
Union Electrician
![]() ![]() ![]() ![]() Maybe I should use that for my ID ![]()
Re: gauge clusters
that is an awsome cluster you have there....very impressive that you have sold so many things and still have 100% satisfaction....you don't see that often...congrats...says alot about you...I was wondering do you do one in green??
I'm Your Huckleberry. You Ain't No Daisy. |
#6 | ||||
Union Electrician
![]() Quote:
![]() ![]() ![]() ![]() Now about the green, if you could get me a pic, or a color sample I can see what I can come up with, if they make the color in the vinyl, I can get paint custom matched like the silver is.The rest of the color I have found a stocked color that matches them.The only problem I see with green is that is that the letters on the lenses I use are green, but I do have a lense I can make up with black lettering,but you can't see the letters and number at night.I haven't used any of this style lens becuase of not being able to see the letter at night and didn't want to risk someone getting hurt, although it looks killer ![]()
Junior Member
Re: gauge clusters
Byrd, those gauges are fricking AWESOME!!! I do have a question on my amp gauge though, do they go out often, as mine just stays in the middle with no movement, when I turn on the headlights, ect.
1970 SILVER CORVETTE COUPE AUTO 1971 SILVER CORVETTE COUPE 4 SPEED 1972 RED C-10 STEPSIDE 3 SPEED 1985 WHITE S-10 BLAZER AUTO 1998 WHITE S-10 4WD PICKUP AUTO 2006 SILVER H-D DYNA LOW RIDER |
#8 | ||||
Union Electrician
![]() Quote:
![]() Have you checked your fuses in the engine compartment? There are two little football looking fuses, one near the battery, and one same spot just on the pass side near the volt reg. Most time that's the problem. Generally I don't see much movement on mine either after initial start up and the alt is charging the batt back up, but I have an int. reg. alt which reacts much faster to changes in voltage/current then the old ext. reg. alt and pretty much takes most of the movement out of the gauge, unless the batt needs charging or you alt is going bad. As far a price on a rebuild it is done to the individuals specs and vary widely in price. PM me what you are looking to do or want to have done and I can give you a price that way...Randy
Junior Member
Re: gauge clusters
Hi, thanks for the quick reply, I do have a new bezel and I have the tach conversion kit coming today or tomorrow and I was thinking I would like a clock or vacuum gauge put in where the spare is. The truck will be painted Silver inside and out at a later date, any thoughts?
Junior Member
Re: gauge clusters
I like the Silver faces but can you do the letters that are green in a black color?
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: gauge clusters
Wow ... i really like those blue backlit ones.
I have a question ... i have a aftermarket tach. Is it possible to change my cluster out and have the tach where my spare gauge slot is right in the middle and use the existing wiring i have for my current tach?
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
Re: gauge clusters
Yes you can.. it takes some modifing though as I did this to mine. I don't have a picture handy, but if you look for the tread that just lists "tach", it's posted there.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
1972 Shorty Owner
Re: gauge clusters
Sweet! ..thx .. i shall PM you soon unless you want me to go through ebay?
#14 | |
Re: gauge clusters
'69cst/10 |
