Old 02-27-2007, 10:25 AM   #1
rhlanham
Unhappy Hard to start 1984 C10
My stepson was given an 84 C10 with the 4.1 L6, 2wd. His cousin that had been driving it said it needed a new carb, as the truck would stall out when you came to a stop unless you put it in neutral and gave it gas. Anyway, I got a reman Holley Rochester 2SE and had it installed by a guy who knows what he is doing. Well, the truck runs ok now (doesn't stall), but it does seem like it is running rich. My guy showed me that when you shut the engine off, you can see fuel being burned in the carb. He could not figure this out for the life of him. Also, when starting, you have to crank the engine for 20-30 seconds, then sometimes it will fire, and other times you have to wait a few seconds and try again, and then it will fire. I'm no mechanic at all, but it sounds like the engine is being very sluggish when it is trying to turn over. What recommendations would anyone have as to what I should have checked out? Thanks for your help!!
rhlanham is offline   Reply With Quote
Old 02-27-2007, 10:59 AM   #2
Donnylee
Donnylee's Avatar
Re: Hard to start 1984 C10
Sounds to me like the float is adjusted to high and your getting spill over when shut off, and nozzle drip when its running. I would have him check the float level.
Donnylee is offline   Reply With Quote
Old 02-27-2007, 12:22 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
to start mine first thing in the morning i crank the engine over a bit the stop pump the gas 2-3 times and crank again (of cource this is in really cold weath like 30-50) in the summer i just pump it 2 time and then crank starts right up. The only think iv learned about carbs is that each one is different.
Srubydo1986 is offline   Reply With Quote
Old 02-27-2007, 02:04 PM   #4
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Sorry, it's shorts and t-shirts weather for us right now and it's 31 degrees out. When you consider we don't even think about plugging the block heaters in until it drops below -10 degrees......
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 02-27-2007, 08:41 PM   #5
Srubydo1986
The Crazy Machanic
well i should live up there i walk in short and a t shirt in the snow al the time people think im crazy. my truck on the other hand likes warm weather just like my chevelle
