![]() Join Date: Oct 2005
steering column ????
hey folks, I have a coworker who needs a steering collumn for his 85 k-5 blazer with tilt. Will a unit from the early 90's work or not,and if not does anybody have one they want to sale?
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
Re: steering collumn ????
If you mean from an early 90's Burb, Blazer, or 1 ton then yes it will be a bolt in. If it is from the later body style it can be made to work, but probably won't be a simple plug and play.
Tonawanda 454
if it is from a 91 and earlier burb/blazer then yes
if it is from a 88 and earlier truck then yes
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
![]() Join Date: Mar 2006
Sry to jack the thread but im looking to put a tilt in my '73 Blazer...what years and model might bolt right in?
1986 C10 - LWB, 305/700r4, posi, vortec heads |
Big Block
I'm not 100% sure but I think from 73 to 87 chevy truck will work. 88 is when the truck body changed. The Blazer and the Suburban didn't change until 92. So you should be able to use a 73 to 91 Blazer or Suburban column. They should all interchange with each other. If I am wrong someone correct me. I just saw screwball's post. So I guess the information is correct.
#6 | |
There was also a change around 77 or 78 where the end of the column was changed from splined to a two flat configuration. You just need to get the matching intermediate shaft to get around that problem. |
#7 | |
72 k5 cst |
Re: steering column ????
ok. so if he finds,,,say, a 90 model pickup will it work as long as the one being replaced has the wiper/dimmer on the column or not? It does have the switches on the column btw., As long as it will bolt up can you change parts around to make it work?
