Old 01-31-2007, 01:18 AM   #1
pissonNOS
senior member
pissonNOS's Avatar
doing a basic bag setup have some Q's
what i will be running will be bags on all corners with stock spindle up front and no notch out back but i do have a 2" block out back now. I plan on swapping to drop spindles and a C notch next winter but for now i want to do the bags . the questions I have are
Will I have pinion angle issues with my setup?
should I keep the 2" inch block out back?
any other things you guys can think I might have issues with or should look out for id be happy to hear other wise from what Ive been told this should be a fairly straight forward setup ? thanks
Jason
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 01-31-2007, 01:20 AM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: doing a basic bag setup have some Q's
heres a pic of my truck just for the hell of it too
69 GMC bagged
Old 01-31-2007, 01:26 AM   #3
XXL
Seņor Member
XXL's Avatar
Bags + 2" blocks will, when dumped, bottom out the axle on the frame (actually, IIRC, just the bags will cause this). Aired up (bag is about 6" ride height), you're going to be fairly close to the frame... so expect to bang it from time to time, or if you carry any significant loads. Given the staged plan you've got, I'd remove the blocks when you install the bags.
For the front... you should be fine.
XXL is offline   Reply With Quote
Old 01-31-2007, 01:35 AM   #4
pissonNOS
senior member
pissonNOS's Avatar
cool thank you also what does IIRC mean haha m sure ive heard before but cant remember
69 GMC bagged
Old 01-31-2007, 01:38 AM   #5
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
although i don't think you will hit the frame when at ride height with the blocks in, with XXL, you will bottom out when aired out, at least to the bump stop.
if you are gonna wait to do the notch, pull the blocks for now.
as for your pinion question, based on what i'v read here, you will need to make an adjustment. if you have a split shaft, one option is to flip the carrier bearing mount in the cross member. there is a post describing this in this forum... i'll find it and post a link.
IvelDesigns is offline   Reply With Quote
Old 01-31-2007, 01:40 AM   #6
jimmydean
jimmydean's Avatar
IIRC = If I Recall Correctly
I have not notched my frame yet, but I am using a 3" cup on the rear. It's not as low as others, but when I'm dumped, the axle is on the bump stops. Not sure how much more it would matter with the blocks.
jimmydean is offline   Reply With Quote
Old 01-31-2007, 01:40 AM   #7
ghetto_superman
ghetto_superman's Avatar
I am also planning on running bags, and am curious as to what all I will need (compressors, single, dual, tanks, valves..) and what a basic setup will cost. Im not interested in fast valves and such that will enable the truck to dance around.. And it doesnt need to lay frame- (All I will have is a small c-notch and 2.5 lowered spindles) I just want it to dump when sitting still and ride somewhere around a 3-5 drop when cruising.
I dont mean to hijack.. I merely mean to expand upon the thread.
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-31-2007, 05:25 PM   #8
leftcoast66
leftcoast66's Avatar
check ***************** they have some starter kits and such. Without the blocks you'll bottom out easily on the frame, I did it for 2 years on mine so been there done that before the notch so you don't need the blocks in because it'll just mean you need more pressure to get your truck raised because of the extra 2 inches the axle is above the mounts.
leftcoast66 is offline   Reply With Quote
Old 01-31-2007, 05:29 PM   #9
XXL
Seņor Member
XXL's Avatar
Expanding the thread further ...
You might want to try the Search feature or browse the several threads in this forum that should address your question about parts needed.
Old 01-31-2007, 08:16 PM   #10
ghetto_superman
ooo touche.
Old 02-01-2007, 12:41 AM   #11
pissonNOS
senior member
pissonNOS's Avatar
I believe your right but mostly ill be driving at ride height and just be dropping it when im parked i should have said that earlier so if i do that i whould be ok?
69 GMC bagged
Old 02-01-2007, 09:32 AM   #12
IvelDesigns
i don't see why not. just make sure you don't go with 1/2 line and valves or the system will be to fast and slam your truck down when you air out. Go with 3/8 and consider getting an adjuster for your dump valves.
Old 02-01-2007, 02:02 PM   #13
XXL
Seņor Member
XXL's Avatar
... 'cept I don't think you'll need the adjusters.
Old 02-28-2007, 10:30 PM   #14
talonted1990
talonted1990's Avatar
Almost all of the trucks we bag come back for adjusters or reducers because we use 1/2" valves. It is easy to use the screw on reducers to make sure the truck comes down evenly, its a little harder to adjust two ball valves to the same speed.
84 C10
95 Chevy Lumina (Daily Driver)
09 Kia Optima (Wife's DD)
73 Plymouth Valiant
talonted1990 is offline   Reply With Quote
