Old 02-20-2007, 09:20 PM   #1
paaw
paaw's Avatar
700r guys
can i get a pic of what kind of bracket you guys are running with the tv cable and intake. Have a regular gm alminum intake 1406 edlb carb and bracket fram summit. and spacer from autozone bracket only long enough to hook in hole by throttle linkage
tci-376700 bracket
thanks chico
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold
paaw is offline   Reply With Quote
Old 02-20-2007, 10:43 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 700r guys
Here is what BTO recommends.
http://www.tvmadeez.com/1406_cam/
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-20-2007, 11:50 PM   #3
powell72
powell72's Avatar
Re: 700r guys
I second BTO, great product.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-21-2007, 12:04 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 700r guys
I took the one that I got from Preimere Performance (Now JET) and remodeled it to a better design and then made my own.
Old 02-21-2007, 01:19 AM   #5
ckhd
ckhd's Avatar
Re: 700r guys
I use the BTO one.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 02-21-2007, 09:17 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 700r guys
BTO is the ONLY way to go, in my opinion.
Not a good pic, but only one I got.
I can post a better one tomorrow of the completed set-up if needed.
The cable plugs into the BTO bracket and you add a cam device to your carb (everything is included in the kit). Seriously, it took about 1/2 hour to install. I had the pan off the tranny and adjusted it by checking the plunger depth and then I fine tuned it using a trans pressure gage.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-21-2007, 08:03 PM   #7
nvrforgotten52
nvrforgotten52's Avatar
Re: 700r guys
i got the bracket that bolts to the intake where the square part of the tv cable clicks in and it bolts right up to the manifold and than i got a B&M cable and B&M adapter that bolted to my edelbrock carb. i havent had a problem since.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 02-21-2007, 09:54 PM   #8
hvychve
To The Levy
hvychve's Avatar
Re: 700r guys
I would agree with the bto guys, thats where mine come from, along with the braided tv cable. There sight also has plenty of insight of setting pressures , which is so critical on these trannys. good luck
hvychve is offline   Reply With Quote
Old 02-22-2007, 09:00 AM   #9
67ChevyRedneck
Re: 700r guys
Here's what the BTO set-up looks like:
Jesse James
Project "On a Dime"
Old 02-22-2007, 06:39 PM   #10
paaw
paaw's Avatar
Re: 700r guys
does anyone have a picture that is using the bracket
Old 02-22-2007, 08:46 PM   #11
Bowtie67
Bowtie67's Avatar
Re: 700r guys
The problem isnt so much the bracket, when using the TV cable for the 700R4 or 200R4 most any bracket will work, the real problem with most carbs is the linkage angle on the carb for the TV cable isnt correct, it has to be right or you will be fighting to get the trans to shift properly. Hollleys, Edle, Demons and a few others need the adapter for the carb and BTO's kit gives you the adapter you need and a proper fitting throttle/tv cable adapter.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 02-23-2007, 10:10 AM   #12
zden
Re: 700r guys
i had the BTO and think it is a waste of money. i never could get it adjusted properly. i ended up getting a factory bracket and have not had any trouble since. the part number for the factory bracket is #14077903. it cost me $9 which is a hell of alot better than $125 for the bto kit.
1966 Chevrolet Suburban
1955 Chevrolet Bel Air
zden is offline   Reply With Quote
Old 02-23-2007, 05:05 PM   #13
powell72
powell72's Avatar
Re: 700r guys
I'm surprised to hear that, I thought it was pretty simple to adjust. I couldn't get the correct adjustment with the factory bracket and my Edelbrock.
Chris
Old 03-03-2007, 11:19 PM   #14
paaw
paaw's Avatar
Re: 700r guys
what all will i need to get with the bto kit, this is all i need to get done before i can start driving tired of it sitting in the garage
Old 03-04-2007, 12:52 AM   #15
paaw
paaw's Avatar
Re: 700r guys
did you guys have to drop pan and but spring in, don't know much about that, is the TVEZ1406 the one I need
