How long does it take to prime a engine?
Title says it all. Im about to prime my 350 and was needing to know how long does it take and when will I know its done?
1st time here so I want to make sure I get it right. Thanks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: How long does it take to prime a engine?
Pull one or both valve covers. Spin the oil pump until oil comes out of the rocker arm holes(where the pushrods seat). You should be good. If you have a mechanical gauge for the oil, you could watch it also, but I like to see it in the top end to be sure its all through the engine.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
Ok sounds good.
67 shorty
IN MY OPINION as long as you have used ample cam lube and prepumped your lifters,it doesnt matter.
67 SWB with enough parts to build two ![]() |
#5 | |
after you do this spin the motor over by hand several times to distribute the oil a bit more.
hey.....smell my finger 64 nova wagon , 63 nova convertible |
`Til the pushrods spit has always been my rule.
depends on what type of paint you're using
Spanked once
![]() Join Date: Oct 2006
Oil based...
If you have to set the lifter preload and are bumping it over w/ remote starter you'll prime it. Or just spin the pump til you have it come outta the oil psi fitting. Shouldn't take but 15 sec. to see psi.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Iwas going to go there and say,"not long.It`s the prep that takes the time.
![]() Join Date: Mar 2003
Well depending on the oil pump--I have had engines prime as fast as a couple of minutes up to 5 +
~Rest In Peace~
have you tried to show the engine some dirty car engine pictures ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
I left out some of the details. The top end had oil already. The reason I was asking about the oil priming is because I had to change out the rear seal. When I was in there my brother n law and I noticed some small specs of dirt on the bearings. No scoring just some dirt. So we cleaned em but I dont have any grease so he said DO NOT START THAT ENGINE UNLESS YOU PRIME IT!!
#15 |
Neighborhood Pickle Slinger
I just got my 327 back together. It was completely empty.
The first time I tried to prime it, no oil came up at all. I removed, took apart and cleaned all my lifters. After doing all that it took about 3 minutes before the first rocker arm was getting oil. After about 12 Minutes all of them were getting oil.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
#16 |
i hope its ok also lol
#17 |
I need to change out my valve covers so what I may do when they are off is to give it another round. Wont hurt anything.
