Old 03-05-2007, 10:51 AM   #1
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
What year ball joints are the same?
Are ball joints (upper and lower) for 73-87 1/2 ton trucks the same as a 72?
and/or
are ball joints (upper and lower) the same from 63-72
I guess the real question here is what year ball joints (upper and lower) will interchange with my 72 spindles on my 69 truck?
I know that I can go to the parts store and get them, but I have some NOS parts and I would like to use what I have if it will cross reference.
THANKS!!!
Bus Ted Knuckle is offline   Reply With Quote
Old 03-05-2007, 03:31 PM   #2
neonlarry
neonlarry's Avatar
Re: What year ball joints are the same?
The differences in the ball joints is in the taper for the spindle they will all mount to the A arms. In your case you would need 71 up joints to fit the taper of 72 spindles.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-05-2007, 03:43 PM   #3
jimmydean
jimmydean's Avatar
71-72 is about it. The 73+ are different.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
