Junior Member
What did you get done this MONTH
Well it's been a little over a month since I purchased the truck, and I have stripped the inside to see if there is any hidden rust and pitched the fuel tank and carpet. But the big accomplishments were purchasing every thing that was missing on the truck including:
Air cleaner and spacer (actually 2 spacers for big block) manifold heat stove, and pipe (actually 2 pipes) the original carb(by Number) the hand throttle the storage box on bedside and door the auxillary battery tray the Big block A/C brackets and a few other misc. original hoses. Pocketbook is a bit lighter but I have a pretty good idea of everything needed to restore it to close to new condition so the body work can start. |
Re: What did you get done this MONTH
I got my frame painted and sitting on the jackstands right side up. I also got a bench seat put in the cab (still gotta get that recovered). Trucks still in pieces though and the engine is still on the stand.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
![]() Join Date: Aug 2004
Got the EFI up and running. Added a 7 circuit fuseblock to run that and any upgrades in the future. I also put on an electric fan.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Bought my truck :-)
1970 C10 ![]() |
![]() Join Date: Jan 2007
- Got new tires to go with the slotted rims I found at the junk yard
- Finally got the front end aligned Had to spend $180.00 for a custom differential cover with drain and fill ports because some jiffy lube jerk stripped out the axel's fill plug - Got a 4 bolt block and steel crank out of a C-50 - Chased a little dog around the house who swiped my keys after I dropped them. - Kicked back with a beer |
