Old 03-06-2007, 08:20 PM   #1
cabinetguy
67 shorty
cabinetguy's Avatar
Rear end Dilemma
I have a 71 5 lug open diff rear and a 67 6lug 3.73 posi . Can I pull the posi out of the 67 and install it into the 71 housing.So as to end up with a 3.73 posi and 5lugs. what kinda setup will this entail
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
Old 03-06-2007, 08:51 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Rear end Dilemma
This should work, the spline set up should be the same. I can not think of a reason it would not work. Just make sure you know what you are doing when you set up the rearend. If you do it wrong you are looking at big problems. Might be worth the 200 bucks to let a pro do it.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-06-2007, 09:09 PM   #3
cabinetguy
67 shorty
cabinetguy's Avatar
I am worried about the old wear pattern on the R&P. It seams that I would have to get it back in the same spot, correct? Oh and $200 bucks......I could just get some axles from summitt
