Old 05-06-2002, 02:41 PM   #1
sigurd
sigurd's Avatar
Post aluminum radiator woes
I bought a new aluminum radiator that is application specific. Problem is the shop sent me one for an automatic. I have a standard tranny. Should I send it back or just plug the holes?
thanks, James
72 SWB K10
San Diego CA
sigurd is offline   Reply With Quote
Old 05-06-2002, 02:57 PM   #2
SCOTI
SCOTI's Avatar
Post
If it's a driver just plug the holes because it won't effect the perf. of the radiator.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-06-2002, 03:03 PM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Hmm..
I didn't know you could get one without the oil cooler. Mine all have the holes pluged.
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
Old 05-07-2002, 10:11 AM   #4
LeRoy
Registered truck nut
LeRoy's Avatar
Thumbs up
I wonder if you could use it to cool your engine oil. Maybe put in a remote filter at the same time. That would really help quench engine heat
MOUNT VERNON, WASH. STATE
GOT MY BASES COVERED
-Big and bad 70 CST Blazer
-71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo,
-Work in progress 72 SWB
-72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd.
-71, 3/4 ton, 402/400, Custom Camper
-69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER"
-69 Chev. short narrow 4x4
-69 Chev., lwb, utility trailer, 35" tires,
Add or Delete Daily
Need a part? Just PM me
LeRoy is offline   Reply With Quote
