Old 03-09-2007, 08:27 PM   #1
nvrforgotten52
nvrforgotten52's Avatar
6/8 drop
i was wondering if anyone has a 6/8 drop on thier 67-72... i am considering a stance like this and want to see it first. pictures?
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 03-09-2007, 09:07 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 6/8 drop
I run my stuff low, but in my opinion, that's too low for a static drop. You'll be knocking your lower control arms into everything.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-09-2007, 09:25 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
Re: 6/8 drop
ECE does not recomend anything lower than a 4/6 without air suspension. If you want to go that low you my want to C notch and bag it.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-09-2007, 09:58 PM   #4
Stroker
Re: 6/8 drop
Anything lower than 6 in the rear and you will have to have some type of frame notch and most likely have to do something with the bed floor to keep the rear end from hammering it.
Up front 4 possibly 5 inches with a static drop using the stock type suspension. The only way I know to get 6/8 without bags would be a 2 inch body drop and a 4/6 static drop. Im not sure what kind of tire clearance issues you might run into if you dropped the front 6 inches.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 03-09-2007, 11:18 PM   #5
Rokcrln
Rokcrln's Avatar
Re: 6/8 drop
I agree! Iwas checking out my truck (low buck) tonight and with a flip in the rear of 6-7" I will only have about 2" untill contact with the frame. I will be doing about a 2"+ notch. The front will be 2.5" spindles and 2" springs. That I feel is the best set up for a static drop. Now my other truck (slow build) has a 2" body drop and bags that give it a total of about 11-13" drop, Here's a pic.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-09-2007, 11:46 PM   #6
magsnubby
magsnubby's Avatar
Re: 6/8 drop
My '71 Cheyenne was my daily driver for about 7 years. I ran 2 1/2" dropped spindles, 3" dropped springs and 26" tall tires (total drop was about 7"). Never again. My headers were about 3" off the blacktop. Jacking that thing up and crawling under it with a torch and a bfh every Saturday got old real quick. My a-arms were so close to the blacktop i couldn't fit an upright pack of Marlboros under them. It didn't take very long to waste 'em both. The front tires would rub hard at full lock on a moderatly step driveway. The back was down about 5" using clamped Chevell wagon springs. Enough to make it sit on the trimmed down bump stops. It was a cop magnet. Never again. Next time i'll bag it and do a c-notch.
I finally jerked the 3" springs and replaced 'em with the stock springs. I trimmed 'em up just enough to give it a 1" drop. I removed the clamps from the rear springs. Didn't look as cool but it sure was a lot easier to drive.
If it's just a weekend cruiser you could get by with a static drop, but for a daily driver it will get old real quick. Save yourself a lot of grief, bag it and notch it.
magsnubby is offline   Reply With Quote
Old 03-09-2007, 11:49 PM   #7
magsnubby
magsnubby's Avatar
Re: 6/8 drop
Rokcrin,
Now that's what i'm talkin' about. That's gonna be one killer truck.
Old 03-09-2007, 11:54 PM   #8
70stroker
70stroker's Avatar
Re: 6/8 drop
My LWB is a 6/7 drop.
front has a 3 inch drop springs and 3 inch Spindles
rear has a flip kit and 1 inch block.
also has a ECE bolt in c notch in rear
70stroker is offline   Reply With Quote
Old 03-10-2007, 01:16 AM   #9
sdkid
Re: 6/8 drop
I love the way yours looks there 70stroker. How much does the flip lower it?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 03-10-2007, 01:23 AM   #10
Rokcrln
Rokcrln's Avatar
Re: 6/8 drop
6" + 1" blocks= 7" in pic
Old 03-10-2007, 01:07 PM   #11
70stroker
70stroker's Avatar
Re: 6/8 drop
Just like Rokcrln said flipping the leafs gave me 6 inchs and then i out additional 1 inch block. the tires are 255/70
Old 03-10-2007, 01:22 PM   #12
see ten
WTB this ad
see ten's Avatar
Re: 6/8 drop
I was unaware ECE sold a notch. Part# or link?
see ten is offline   Reply With Quote
Old 03-10-2007, 06:12 PM   #13
Jaredm82
Active Member
Jaredm82's Avatar
Re: 6/8 drop
I think 3" springs + 3" spindles in the front with stiff shocks and 6" springs + 2" blocks + CPP notch in the back would be *****in! I almost wish I didn;t cut up the back of my truck and done this instead of airbags and stuff...
Jaredm82 is offline   Reply With Quote
Old 03-10-2007, 09:56 PM   #14
70stroker
70stroker's Avatar
Re: 6/8 drop
Hey i went thru all my old receipts today, sorry the c notch is a mcgauphys it it cost me bout 60 bucks for the bolt in on and then i welded around it also.
The 6/7 drop rides fine. a little siff, and it isnt not lincoln but i mean none of these old trucks are. i used to have a 88 iroc camaro it rides about the same. no bottoming out problems either.
Old 03-10-2007, 10:13 PM   #15
SCOTI
SCOTI's Avatar
Re: 6/8 drop
Front: 3" spindles w/1 coil cut from stock 6cyl springs, 1.25" 1-ton sway bar w/urethane bushings w/no frame extensions (stanchions)
Rear: 2600# bags, 1.5" blocks, c-notch, re-located/modified stock shock brackets, adj. track-bar
Exhaust was tucked up as high as possible to the frame . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-27-2007, 01:31 AM   #16
nvrforgotten52
Re: 6/8 drop
here is my truck before and i wanted it lower
so i went 5 inch springs with 3 inch blocks in the back and custom c notch
and 21/2 inch drop spindles with 3 inch spring in the front.
so now i got your hopes up and no i havent put the bed or the front clip back on yet but it will be soon however, my lower control arms are plenty high from the ground in the front and rear of the truck and i am going to run my exhaust though the crossmenber which i cut 4 inch holes in and the only thing i might catch on some things is my longtubes but i think im going to swap them to a mid.
