Old 03-10-2007, 09:49 AM   #1
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Question 2wd to 4wd swap???
I did some searching and can't seem to find the answer.
All these Gr8 looking swb 4x4 have me thinking and I only have money for one truck.
Question: Using these two trucks in my Sig. 72 swb 2wd and 72 lond bed 4x4 can I convert the swb 2wd to 4x4.
Even if it's not a direct nut and bolt swap. I don't mind doing some fab. work but really don't want to get into major custom fab. work. Either way this is going to be a frame up build starting soon as it gets alittle warmer.
I had heard that you could but, thought I read on here somewhere that you can't. Don't have both trucks side by side to compare.
Even just threads that are alredy on here would be Gr8 if this is possible.
Thank you in advance, RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-10-2007, 10:22 AM   #2
JimKshortstep4x4
Re: 2wd to 4wd swap???
My thought would be to use the 4x4 long bed frame, shorten it by 12" and cut 8" off the rear. All of your short bed sheet metal should fit your reworked frame. I believe the bed mounts would have to be addressed as well as shortening the drive shaft.
Trying to remount the springs from the long bed to the short bed frame seems like a job!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-10-2007, 10:33 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
You could shorten the LWB frame, or you could buy my 70 SWB 4x4 frame + matching vin tag. I just bought another out of Cali. and will most likely be putting the 70 up for sale when it arrives. It's been sand blasted & painted, no rot throw anywhere but has pitting. Solid frame !!! ( Located in NH )
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-10-2007, 11:58 AM   #4
1969k10stepside
Warning:Shortbed 4x4 Chassis's arent cheap.Well,except mine....
Anyway,your best bet besides buying a shortbed 4x4 chassis would be to cut down the longbed 4x4.Does the 2wd shortbed have a coil spring rear end?If so then I would eliminate the 4x4 convert using it.
1969k10stepside is offline   Reply With Quote
Old 03-10-2007, 04:02 PM   #5
RACINJASON22
GEARHEAD
Custom/10 thanks for the offer but, I'm trying to figure it out with one of my frames if I can.
1969k10stepside The swb is a coil truck arm rear.
So I guess what your telling me is that I can't do away with the coil rear components and bolt all the leaf rear on to my swb frame and then do the same with the front engine cradle and components.
Main Question: Is a swb frame itself different from 2wd to 4x4. Maybe I'm not asking this question right or in the right words. Thanks RJ22
Old 03-10-2007, 08:34 PM   #6
1969k10stepside
The 2wds with coil springs are a totally different frame,there is bends in it the leaf springs trucks dont have.I have a thread with pics comparing the 2 frames,I will dig it up
Old 03-10-2007, 08:44 PM   #7
1969k10stepside
I found my thread with pics comparing the frames.Oh,and I threw in the latest shortbed 4x4 pic I have of mine
link
Old 03-10-2007, 10:20 PM   #8
RACINJASON22
GEARHEAD
Thank You 1969k10stepside for the link that was exatly what I was wondering.
My original plan was to build the 2wd and then the 4x4 the way they were but, money is making me lean toward only one build. That means sale or part out the other to help fund the one I build. I have a little while till warmer weather to figure it out.
Thanks again RJ22
Old 03-10-2007, 11:22 PM   #9
earl87gta
earl87gta's Avatar
do a search for posts from ABholer he has done this with his burb. all he did was flip the rear axle so it was under the rear control arms. used the front spring perches and crossmber from a 4x4. steering you could go to cross over and keep the 2wd box or standered steering using the 4x4 steering box. Its not that hard of a swap he has some pics on his web site I dont have the link here but Im sure some one here may have it.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-10-2007, 11:58 PM   #10
RACINJASON22
GEARHEAD
earl87gta thanx for the tip. Sounds interesting....hmmm different 4x4 truck arm rear. I'll check it out. Still debating on what to do so all options are open at this point.
2wd, 4x4, swb, lwb, lifted, lowered, too many options too little time!
Old 03-11-2007, 09:51 AM   #11
jacobs
jacobs's Avatar
I installed a 73 Blazer complete running gear under my 70 c/10 with coil springs 15 years ago. It was easy to install the leaf springs in place of the coils. Frame rails are the same width. Just welded the old Blazer spring hangers on the 70 frame and the rest just bolted right on. Yes, the frames are different in back but that isn't a problem when going to leaf springs. You can't change from factory leafs to coils though. I don't understand why GM made frames different between coil and leaf springs. I guess they just didn't like simplicity.
jacobs is offline   Reply With Quote
Old 03-11-2007, 11:28 AM   #12
GMCMAX
Active Member
GMCMAX's Avatar
If you convert the 2wd, it will need the high hump floor to clear the trans/transfer IIRC. I did mine, but it already had rear leaf. The front stuff will bolt in with some mods such as flattening or cutting out the big dimples where the e-brake goes through-- thats where my front spring mounts went.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 03-11-2007, 11:42 AM   #13
GMCMAX
Active Member
GMCMAX's Avatar
This one was for sale,I saved the pic from the ad, it has the rear axle on top of the arms and some other rear mods
Gets More Chicks
Old 03-11-2007, 01:16 PM   #14
RACINJASON22
GEARHEAD
Thanks for all the replies. I'm still debating on which way to go but, all this info is helpful. I see the difference in the frames in the back. I was wondering if any body did the swap like jacobs did discribed. I thought it may have been possible. I want to get these two trucks side by side and do some real good comparisons when I do I'll list some pics with details. Thanx again everyone.
Old 03-13-2007, 10:33 PM   #15
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Jason
Where is central PA at? I`m here in Manheim thats central PA to.
Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 03-13-2007, 10:53 PM   #16
RACINJASON22
GEARHEAD
67-72williso I'm Right in the middle I would guess Philipsburg would probably be the closest town you might have heard of. I live in the sticks Osceola Mills is tha actual address 16666 zip but I really don't live IN that town either. My addess should be middle of the woods central Pa. 20min northwest of State College RJ22
