03-09-2007, 08:46 PM | #1 |
ohm help
I am electical handicaped if I want to check if a wire is good from one end to the other I can use my multimeter on ohms correct? So I set it on 200 and touch both ends it buzzes and reads .3 is that good?
Thanks for your help.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
03-09-2007, 08:57 PM | #2 |
Re: ohm help
That's good
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
03-09-2007, 09:06 PM | #3 |
Re: ohm help
Thats good. Try touching your leads together it will probably read .3 ohms also
03-09-2007, 09:22 PM | #4 |
Re: ohm help
if u want to get a better reading of a wire and its conductivity, put your meter in the DC voltage setting and put each lead on each side of the wire with current flowing through, if it gives u more than .2v then u need to replace it. this is referred to as a voltage drop test and MUCH more effective than a resistance test.
03-09-2007, 09:35 PM | #5 |
Re: ohm help
My meter does not have that setting I dont think not very high dollar.
03-09-2007, 09:51 PM | #6 |
Re: ohm help
can u take a pic of it?
03-09-2007, 09:56 PM | #7 |
Re: ohm help
look for settings that say dcv or acv
03-09-2007, 11:56 PM | #8 |
blood type; Retumbo
Re: ohm help
general rule of thumb; when doing a voltage drop test you should not have more than .2V drop for each connection. (this is why crimp connectors are bad and soldering is best.)
03-10-2007, 12:14 AM | #9 | ||
Re: ohm help
and on the crimp connectors/butt splices, as long as they are not exposed to the elements, they would be find to use...other wise just use good ol' heatshrink |
03-10-2007, 10:13 AM | #10 |
Re: ohm help
no niether of those settings.
03-10-2007, 04:49 PM | #11 |
Re: ohm help
