Active Member
Re: 6/8 drop
I think 3" springs + 3" spindles in the front with stiff shocks and 6" springs + 2" blocks + CPP notch in the back would be *****in! I almost wish I didn;t cut up the back of my truck and done this instead of airbags and stuff...
Re: 6/8 drop
Hey i went thru all my old receipts today, sorry the c notch is a mcgauphys it it cost me bout 60 bucks for the bolt in on and then i welded around it also.
The 6/7 drop rides fine. a little siff, and it isnt not lincoln but i mean none of these old trucks are. i used to have a 88 iroc camaro it rides about the same. no bottoming out problems either. |
Re: 6/8 drop
Front: 3" spindles w/1 coil cut from stock 6cyl springs, 1.25" 1-ton sway bar w/urethane bushings w/no frame extensions (stanchions)
Rear: 2600# bags, 1.5" blocks, c-notch, re-located/modified stock shock brackets, adj. track-bar Exhaust was tucked up as high as possible to the frame . . ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-10-2007 at 10:14 PM. |
Re: 6/8 drop
here is my truck before and i wanted it lower
![]() so i went 5 inch springs with 3 inch blocks in the back and custom c notch ![]() and 21/2 inch drop spindles with 3 inch spring in the front. ![]() so now i got your hopes up and no i havent put the bed or the front clip back on yet ![]()
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
