Old 11-21-2002, 03:01 PM   #1
Purs
Got Big Block?
Purs's Avatar
Springs Re-Arched?
I'm looking for about 1"-2" of lift for my 4X4 and a friend of mine said instead of getting a lift kit just get my springs re-arched. Has anyone done this and does it work? Also, how would my ride compare?
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 11-21-2002, 03:13 PM   #2
Mudder
Mudder's Avatar
They can be
But sometimes the arch comes out on one or the other from what I've heard. Not 100% sure tho. The place may give a warrenty on this too. Wouldnt hurt to ask.
Mudder is offline   Reply With Quote
Old 11-21-2002, 05:30 PM   #3
Dutch
Exclamation
I saw these and they look like a slick way to bump the height a touch with no change to your ride.... check the rest of this site out too. pretty cool 4x4 toys.......
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Dutch
1972 Super Cheyenne K20
1976 MGB
1950 Harley FL
1997 Arctic Cat ZR580
"Maybe if I had a couple less hobbies, I'd have time to enjoy one!"
Dutch is offline   Reply With Quote
Old 11-21-2002, 05:37 PM   #4
Dutch
Exclamation
Dutch
1976 MGB
1950 Harley FL
Old 11-21-2002, 05:48 PM   #5
Purs
Got Big Block?
Purs's Avatar
thanks Dutch! Looks interesting. Does anybody have any experience with these?
Old 11-21-2002, 06:04 PM   #6
Spoof
Spoof's Avatar
I had the springs on my s-10 re-arched about four years ago and have had no probs with sag or balance. I also had my 2500 leafs DE-arched for a drop and they came out level. It's cheap but can be some work removing and re-installing, but you can get the bushings redone at the same time.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 11-21-2002, 08:07 PM   #7
Blue_71
Bloo
Blue_71's Avatar
i dont know yet, but im getting a set of these i got off ebay for my truck.. sending money tomarow, once i get em in ill report back
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 11-21-2002, 09:33 PM   #8
Bowed
Like MUDDER 67 said they quite often sag even after a short period of time because of different factors like spring pack design , condition and ECT . and this will happen more on heavy pick up trucks . If you are going to keep the truck may be it would be better to put that money toward new springs . , but if you are tight for money you can do your own re-arch with a torch but probably the easiest way for a 1 1/2 to 2" lift is to put an " Add a leaf kit " on the front and a small lift block on the back , this might cost $100. for the kits and give you up to 2" with little change in ride .
Bowed is offline   Reply With Quote
