03-10-2007, 06:40 PM | #1 |
need help with vin#
my vin#ccs132a...... can't find second c in vin# codes.cab has cab lights and factory shift on floor on 1/2 ton swb frame..help...
03-10-2007, 07:23 PM | #2 |
68 just like me
Re: need help with vin#
does it list the same series inside the dash and the drivers door. all I can find is conventional cab 6 cyl. fleetside 1972 from Atlanta.sorry no help you probable already know all that.on a side note my Dad might have built your truck he worked at the atlanta plant maybe I should call him.
68 just like me |
03-10-2007, 07:48 PM | #3 |
its all about the +6 inches
ccs132a
The added C is a 72 thing...it means Chevy. If it was a GMC, it would be a T So you have; C Chevy C2 wheel drive S inline 6 1 1/2 ton 3 i can't remember what 3 is... cab chassis maybe? (does it have a bed on it? 2 1972 A built in Atlanta Here is our VIN decoder http://67-72chevytrucks.com/Chevyear.html |
03-10-2007, 07:49 PM | #4 |
BTW, There is no way to say fleet side or step side on a chevy VIN.
03-10-2007, 11:08 PM | #5 |
thanks longhorn.just picked the truck up today,along with a 70 step side.the 72 is in preety bad shape,not sure if it's worth fixin..have complete floor to get it done.just never seen cab lights and shift on floor in 1/2 ton,also has radio delete.would like to know if it is some special model...cab is not round where cab lights are,has slight risen flat surface..weird...thanks ..
03-10-2007, 11:15 PM | #6 |
clearance lights were uncommon, but not unheard of on a 1/2 ton, 4 speeds, not uncommon at all. The raised pads you mention, that ensures the lights were on that truck from day one.
