Old 03-11-2007, 01:24 AM   #26
mudmizer
mudmizer's Avatar
Re: dana 44 spicer hubs dials
Mine have been cleaned up and are working great. One of the plastic dials broke where the pin goe's through, one hole only, I drilled new holes clocked over about 6 degrees and it works just fine. Of course it dosen't have the little extra bit of plastic like the original hole area and the dial pointer is off just a tad, but hay it works for now. Metal would be great in the furure.
Special-K your right the machinest would need to take in accout the coating. A nice lathe and they could be fairly easy to make. Good idea.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 03-11-2007, 06:36 AM   #27
Mudmizer,I did the exact same repair before.I couldn`t find the right split-pin,so I used a drill bit.It worked out just fine.I`m more picky,now and that would bug me on a "classic",though.(I`m sittin`on n.o.s. hubs,now)
These metal dials are a great upgrade.I always got the Warn Premiums because I didn`t want plastic.I think the powdercoat could be omitted,though.I think it will lift at the edges and peel.Especially with aluminum.Oxidation will get under there and pop it off.This is my opinion.I`ve had alot of experience with powdercoat and it`s got it`s limitations.It could last a good while,but I`d keep the material raw.You`re using premium corrosion-resistant metals anyway.
Old 03-11-2007, 09:26 AM   #28
CrashEd
72 chevy
CrashEd's Avatar
Ill have to get a picture its like a full time hub iv never seen this kind before. I think i found a set of lockouts though ill post some pictures.
Ed
CrashEd is offline   Reply With Quote
Old 03-11-2007, 10:37 AM   #29
Oh,ok.You don`t have the lock-out option.Which is rares than having the option.I`ve,personally only seen a few and they were all 1/2t.It`s just a slightly convex plug.You need the complete l/o assembly.I`d like to see a pic.
Old 03-12-2007, 11:45 PM   #30
mudmizer
mudmizer's Avatar
Went to the 4X4 swapmeet in Puyallup, WA. this last weekend an found a fella that had two sets of the hubs, spacers and all, with a few extra parts and ALL GOOD DIALS, excelent shape. everything for $25.00.
Sooo... I'm good for a while.
Old 03-13-2007, 01:20 AM   #31
CrashEd
72 chevy
CrashEd's Avatar
Heres a picture of the as you call it no lockout option and one of my lockouts i just found for the truck.
The 2 lugnuts are the no motor option LOL!!
And its a mud truck no reason to get fancy lockouts.
Ed
Old 03-22-2007, 01:27 AM   #32
454_72_4X4
454_72_4X4's Avatar
Attachment 250066
Attachment 250065
Ed
Hey Ed, I've got 1 or 2 of those, (I call 'em drive flanges), no lochouts layin around somewhere. I thought they'd be handy to carry one around with me in case I broke a lockout hub sometime.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
