Old 02-17-2007, 12:08 PM   #1
cruisinlow67
Rear Lowering Blocks
im looking for rear blocks for a 67 c10. ive looked at ece and brothers. i want a 2 inch or bigger. who has them? i need these to complete my bag setup for the rear.
cruisinlow67 is offline   Reply With Quote
Old 02-17-2007, 12:58 PM   #2
tom71
what happened to flint mi
tom71's Avatar
Re: Rear Lowering Blocks
i got mine from ccp
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 02-17-2007, 01:00 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I made mine out of 2" square 1/4" wall tubing. For "U" bolts look in the yellow pages under "Springs-Auto Sales & Service". Take one of the "U" bolts to the spring company and tell them you need two of them 2" longer. Runs about 30 bucks. You can probably buy them on line also.
LockDoc
Leon
Old 02-17-2007, 01:08 PM   #4
cruisinlow67
whats the ccp website?
Old 02-17-2007, 11:18 PM   #5
st1x10
st1x10's Avatar
Might check here
http://www.performanceonline.com/sto...cat=785&page=1
They have 2" blocks.
CPP is.
http://www.classicperform.com/
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 02-21-2007, 07:21 PM   #6
nvrforgotten52
nvrforgotten52's Avatar
does anyone know if you can get just the u bolts online? and where?
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 02-22-2007, 01:16 PM   #7
T-H
T-H's Avatar
I found a place online called DJM suspension when I was look for suspension components for my truck, they do have a lowering block kit for 63-72 Chevy Trucks and it does come with U-bolts, they also have a plain U-bolt only kit if you want to get the block somewhere else.
http://www.stylinconcepts.com/parts....wering%20block
T-H is offline   Reply With Quote
Old 03-12-2007, 12:22 AM   #8
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i saw this post and ordered me a set of U-bolts from those guys. They won't work. They are way smaller than the factory bolts, and do not fit in the trailing arm holes. I'm going to call them tomorrow and see about getting them swapped for the right ones.
btw, I made my own blocks this weekend out of 2.5" x 2.5" x .25" square steel tube and i think they will work great. I have some extra steel left and wouldn't mind making a set or two for board members. I posted in the classified section more details.
IvelDesigns is offline   Reply With Quote
