03-12-2007, 10:42 PM | #1 |
GM ONLY BABY!!!
Swapping leafs to trailing arms?
It looks like I will be changing my leafs to trailing arms. What all is involved?
This is what I can think of: New front control arm bushings Coil springs and plates or clamps and bolts 2 rear shock brackets U-bolts and nuts Weld on panhard bar-because I will be using the leaf spring rearend Weld on trailing arm pads 2 crossmember brackets Anything else I'm forgetting? Anyone else done this, and have some tips for me? Maybe I should take some pics of my work.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
03-13-2007, 01:11 AM | #2 |
Re: Swapping leafs to trailing arms?
There's 2 upper & 2 lower shock brackets.
You'll need the coil spring reinforcement c.member (which also is where the top shock mounts attach). Front trailing arm brackets (leaf suspensions have the crossmember w/o the brackets). You can use an ECE Super track bar. It bolts in on the pass side trailing arm & runs across the frame to the driver side (you will need a bracket there).
