Old 03-11-2007, 11:28 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Q-jet Carb Trouble
So heres the problem, when the truck sits for a couple days, it is a complete pain in the a** to start, cranks and cranks for a long time, and then slowly starts to fire, once its running once during the day it will start perfectly barley even turn over and she's running. Any ideas on whats happening, ever since the carb was rebuilt it has been doing this, and to top it off the guy that did the rebuild has skipped town.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 03-11-2007, 11:40 PM   #2
regal8r
Re: Q-jet Carb Trouble
IIRC thats just how a carburated engine is...do u pump the pedal before starting it after it has been sitting a while? if so, your accelerator pump might be shot. could also be a fuel pump problem.
regal8r is offline   Reply With Quote
Old 03-11-2007, 11:51 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Don't know if this is your problem or not but it sounds like it.
http://ramchargercentral.com/index.p...howtoshow;id=6
LockDoc
Leon
Old 03-11-2007, 11:57 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
regal8r, my other trucks fire right up, even after sitting for a month, and yes i giver a pump or 2 to prime it and set the choke.
87 Chev 3+3 4x4
Old 03-12-2007, 12:02 AM   #5
pimperout
pimperout's Avatar
i have the exact same problem i have found that when i pump the gas exactly 5 times it will fire up like nothing
pimperout is offline   Reply With Quote
Old 03-12-2007, 12:07 AM   #6
regal8r
sounds like its a fuel pump problem then
Old 03-12-2007, 12:12 AM   #7
Blue85
Oilfield Trash
Blue85's Avatar
thought about the pump, but if i pull the fuel filter from the carb, there is lots of gas in the housing, think i'm gonna swap carbs with another truck and see if it starts better if no difference then i'll try a different pump
87 Chev 3+3 4x4
Old 03-12-2007, 12:22 AM   #8
jhow66
jhow66's Avatar
Sounds like your main well plugs are leaking. Carb is empty when you go to start it. Next time it sets for a few days before you go to start it pour a little gas in carb. If it starts right up and then dies this may be your problem.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-12-2007, 12:29 AM   #9
jhow66
jhow66's Avatar
This will show you what I am talking about. (scroll down to #12 photo)
http://www.carcraft.com/howto/57178/
Old 03-12-2007, 12:34 AM   #10
oldiron
Designated Grumpy Old Man
oldiron's Avatar
I agree with jhow66 about the leaking plugs. Q-jets were famous for that.
oldiron is offline   Reply With Quote
Old 03-12-2007, 12:38 AM   #11
Blue85
Oilfield Trash
Blue85's Avatar
thanks for all of the input guys, i got another question for you, my buddy has a 81 that floods itself out when the motor is warm, and he shuts it off. Starts great when cold though, any ideas?
87 Chev 3+3 4x4
Old 03-12-2007, 08:44 AM   #12
cooters
your buddy may have a choke that does not open completely. On yours, before starting , remove air cleaner and manually hit the throttle and watch for fuel to spray from the accelerator pump nozzle. My guess is there will be no fuel. Keep pumping till you see fuel, how many pumps does it take?
cooters is offline   Reply With Quote
Old 03-12-2007, 09:34 AM   #13
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I lightly scanned the above, Have you checked your "Acceleration pump" the one that squirts a stream of gas into the barrels when the pedal is pushed?
Sounds like you may not be getting the fuel you need for startup.
sneakysnake is offline   Reply With Quote
Old 03-12-2007, 11:08 AM   #14
WorkinLonghorn
WorkinLonghorn's Avatar
Jhow66 nailed it. That exact same problem (leaking Q-Jet) saved my last '69 from being stolen,they couldn't get it started. But I've heard that gas trickling down into your engine can wash away the oil in the cylinders and cause extra wear there so you really should pull it off and seal it up.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-12-2007, 03:02 PM   #15
Blue85
Oilfield Trash
Blue85's Avatar
Man do i ever love this site, tore down the carb today, and sure enough, I could see where the old expoxy was detereoraited and the plugs were leaking from, so i ground the old junk out and resealed with jb weld, find out tomorrow if it worked. Any other tips on things i could do with the carb while its apart?
87 Chev 3+3 4x4
Old 03-12-2007, 04:57 PM   #16
jacobs
jacobs's Avatar
The nozzles where the fuel is discharged into the venturies from the accelerator pump will sometimes plug. I've had this problem several times. Right now, one of mine is plugged and I need to fix it. If both plug, it's the same symptoms as a bad accelerator pump.
jacobs is offline   Reply With Quote
Old 03-12-2007, 05:28 PM   #17
gmc1969custom
It sounds like you have your problem solved but you might also want to make sure your choke is working properly, I was having the same problem a few weeks ago. My problem was my choke linkage, it was not allowing the front butterfly to close completely on a cool morning. Now after a little bit of tinkering and freeing up the linkage, I just get in my truck, pump it once and within 2-4 seconds she fires right up everytime. Pumping it a few times doesnt hurt anything, but IMO a properly tuned Q-Jet should only have to be pumped 1 time to set the choke and it should fire up within seconds.
1969 Custom w/Turquoise Interior. 75k miles, 350 V8, THM400 (Almost) All Original
gmc1969custom is offline   Reply With Quote
Old 03-13-2007, 07:21 PM   #18
Blue85
Oilfield Trash
Blue85's Avatar
Well, i sealed up the holes, put a new accelerator pump in it, put it back together, installed it, and it fired up right away, now the real test is when i leave it overnight and see how it starts tomorrow. Thanks alot to everyone who helped me solve the problem.
87 Chev 3+3 4x4
