Old 03-14-2007, 03:48 PM   #1
jeff1vol
jeff1vol's Avatar
Question regarding adjustable panhard
rods. I recently bagged my truck (no c-notch or drop spindles) and it sits like I want it to and still has a great ride.
Anyway... I recently put some 10" rally's on the rear and I noticed that the drivers side wheel sits out further in the wheel well than the passenger side. First, I thought that the wheels had different backspacing, but after checking they are alike, so...
Does this mean that the rear end is NOT tracking correctly? I wouldn't have thought that it would have made THAT much of a difference with a 5- 5.5" drop. I would say without measuring that it is easily an inch difference between the passenger side and driver side. And yes... I CAN eyeball an inch or two difference If it were the average "joe" they probably wouldn't notice, but it's my truck and I can damn sure notice! Let me know what you guys think.
Thanks,
Jeff
jeff1vol is offline   Reply With Quote
Old 03-14-2007, 04:03 PM   #2
jimmydean
jimmydean's Avatar
Re: Question regarding adjustable panhard
Adjustable rod for anything over 4" is what I was told. My truck is bagged with a 3" cup (no notches) and I went with the CPP "deluxe track bar" and it seems to work well. It goes from the passenger training arm to the stock frame mount. on sale it was $100.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-14-2007, 07:20 PM   #3
jeff1vol
jeff1vol's Avatar
Thanks Jimmy! Did your truck's rear end sit to one
side as much as mine did? I'm just hoping this fixes it and I don't have something bend somewhere!
Old 03-14-2007, 07:28 PM   #4
72 cheyenne pdx
72 cheyenne pdx's Avatar
Did you get your truck re-aligned after the air ride was installed? If not, you should take it to your local shop and have that done.
Good Luck
72 cheyenne pdx is offline   Reply With Quote
Old 03-14-2007, 08:01 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
I did a 5" drop on the rear of my truck and my rear end was off towards the left a good bit, same as yours. You could easily see the driveshaft pushed to one side as it headed towards the center support. Recently I ordered the ECE Super Track Bar and it helped a lot and was easy to install. Everything I have read states that it's essential to use an adjustable bar for drops 4" or greater.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
