Dave's not here, man
Need Help with Carb. Linkage
I just got a new 2 bbl Rochester for my truck and the linkage that the accelerator rod clips to is different than my other 2 bbl. It has a much larger diameter. Does anyone know what type of rod/clip I need? Here are some pics; the first one is the old linkage and the second is the new one. I drilled a small hole through the old linkage, pushed it through and installed a cotter pin for a temporary fix. Thanks in advance for the help.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Insert Title Here
Re: Need Help with Carb. Linkage
All I can say is that is the exact same thing I did, with the cotter pin and all, when I changed carbs
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Have you had any problems with binding/sticking? Mine's been o.k. so far, but I'm kind of paranoid
ttt
Insert Title Here
It doesnt seem to bind, but its not how I plan to keep it... im still looking for something else... my rod is straight, not bent like yours, so you might be better off than mine is
