11-19-2002, 12:49 PM | #1 |
BEER-Vacation in a can...
alternator brackets
mine is about trashed and it doesn't really fit right in the first place, i talked to summit and they have 2 kits that they will garentee fit but they are $160. i have a short water pump (which is being the sticky point, i know) headers, tall valve covers and a performer RPM manifold. alt on the drivers side. i couldn't afford to do change everything to long mount stlye when i put the motor in and now am debateing if i should do it now or spend the money on the short pump kit or see if there is a better third idea out there.
Kurt 03' Trailblazer 69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik 2000 Yamaha V-Star 1100 Custom For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics |
11-19-2002, 01:51 PM | #2 |
Do you have the factory truck setup on there now?
Jim |
11-19-2002, 02:33 PM | #3 |
yes it is the factory set-up, thats why it doesn't fit quite right. the alt is the only acc i have now but will be adding powersteering some day. thanks for the help
11-19-2002, 07:35 PM | #4 |
do a search on alan grove industrys...they have great products,,I have their short water pump alt brkt..like 75.00..its great
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
11-19-2002, 08:11 PM | #5 |
Sounds like junkyard time. I bought the brackets for alt. at a junkyard for $15 , and it came with the altanator. And i got the power stearing pump and bracket and hozes for $35.. I love going to junkyards and looking around.
good luck... Randy
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
11-20-2002, 03:48 AM | #6 |
tried the junkyards, problem is the tall valve covers, nothing stick had them so nothing stock fits over them, Bigjim do you have a website or anymore info on alan grove? i did a search and found nothing
11-20-2002, 08:22 AM | #7 |
We cut the alt bracket in the fat area about an 1 1/2" from the adjuster groove and add 1" to it, grind the welds and paint, powder coat or chrome it. Make sure when you weld it that it clears the alt fan.
Rest in Peace Ed. Thanks for all the good times. |
11-20-2002, 09:50 AM | #8 |
http://www.streetrodcatalog.com/manu...e_sbcswp.shtml
couldnt find alan groves site...these guys sell the brkts for 80.00...alan grove must of gottten too big to sell out of theyre own site jim
11-22-2002, 01:38 PM | #9 |
Try this on...It's a '98 350 setup out of a Z71 pickup. All the accessories and water pump. I've since replaced the fan shroud with a BB and it looks much better now.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
11-22-2002, 01:40 PM | #10 |
oops, wrong pic...
11-22-2002, 06:43 PM | #11 |
THE QUICKER FIXERUPER
Alan Groves site is www.alangrovecomponents.com
