Old 03-14-2007, 10:39 PM   #1
wibilly
wibilly's Avatar
69?'s
i just bought 2 69's 1 custom 10 and 1 custom 20 with leaf springs and a dana rear 350 th 400 1st ? what would be standard gear ratio if none is listed and ?2why do some door panels have the bow tie and some not , is that a year thing and they wer changed in one truck, sorry no pics yet
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-15-2007, 07:54 AM   #2
GMCBubba
GMCBubba's Avatar
Re: 69?'s
with the 3/4 ton and dana rear, i think it should be 4.10. at least, mine is and i have no other listed ratio
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 03-15-2007, 07:58 AM   #3
Re: 69?'s
Ratios are never listed.The bowtie was`69-only.
Old 03-15-2007, 01:19 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 69?'s
the69 was a one year only door panel, and there are 2 versions as you've seen. I can't remember which way it goes, but one is early, and one is late. I have one of one style, and one of the other style on mine.
i *THINK* the bow tie is early, and blank is later... but I could be wrong on that... I have a 50/50 chance.
Old 03-15-2007, 01:20 PM   #5
Longhorn Man
Re: 69?'s
oh, almost forgot the gearing Q...
a 1/2 ton... small block and auto, with no gear listed, should be a 3.07
A 3/4 ton equipped th4e same way, would be a 4.10.
Old 03-15-2007, 05:16 PM   #6
Bob Moore
Re: 69?'s
I have a D60 that is a 3.54.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-15-2007, 05:32 PM   #7
Longhorn Man
Re: 69?'s
that would have beena big block truck
Old 03-15-2007, 07:03 PM   #8
wibilly
wibilly's Avatar
Re: 69?'s
thanks all was hoping i had the 3.54 ratio becausei;m thinking this is the truck needing the 500 caddy
Old 03-15-2007, 07:14 PM   #9
Longhorn Man
Re: 69?'s
you'll want better gearing for a cad.... trust me
