Old 03-16-2007, 01:31 PM   #1
hewlett2002000
hewlett2002000's Avatar
i cant win for losin!!!!!!
well i am still having overheating problems. so ive been out all morning tryin to find a problem. well i found more than i wanted to find. i told a buddy of mine that it only overheats when it was being drivin. he said it could be alot of things including a cracked or warped head. turns out that water i thought was condensation wasent, it was coolant. so i guess i have a cracked head. could a blown head gasket do that too?
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-16-2007, 01:39 PM   #2
UltraRick
UltraRick's Avatar
Re: i cant win for losin!!!!!!
The short answer is yes it could. CHeck your oil coes it have coolant in it, frothly looking? If yes then it probably the head.
UltraRick is offline   Reply With Quote
Old 03-17-2007, 11:08 AM   #3
hewlett2002000
well it was a blown head gasket. me and a buddy fixed it. what a pain in the a**. but its still overheating. ive got an old radiator from a 65 and im gonna put that in there and see if it still overheats, but that one has a small leak and alumaseal wont fix it. if that fixes it then im gonna buy a new radiator. right now my truck has a IL6 radiator in it, so i think its too small. anyways, ill let ya know what happens. thanks for the help.
Respect:
Old 03-17-2007, 04:01 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
It is possible the old radiator is clogged up and their is not enough coolant flowing.. I would not drive it with the old radiator.. I think if you want an aluminun radiator will fit if you get an application that fits in a nova.. I am not 100% sure of this and yes some fab work will have to be done.. I will be getting one for mine and will probably sell my old/new radiator with electric fan attached but may save it just in case i get another old truck...
Chevy Fleetside is offline   Reply With Quote
Old 03-17-2007, 08:47 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Which generation Nova ??
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-17-2007, 09:04 PM   #6
Chevy Fleetside
68 to 74 Nova.. I am going by the summit cataloge.. http://store.summitracing.com/partde...0&autoview=sku I was just going by the measurement in the book.. It seems like it would fit just right..
Old 03-17-2007, 09:24 PM   #7
19GMC63
19GMC63's Avatar
I used an even cheaper universal one from summit, fit perfectly in the lower mounts, just had to fab up some simple L-shaped upper brakets.
Its a very nice fit, top sits flush with radiator support.
heres a pic before the upper brakets. I just bolted the brakets where those two existing bolts are on top. Its not a very pretty setup, but it works, and cools very well.
19GMC63 is offline   Reply With Quote
Old 03-17-2007, 10:40 PM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I think my Rock-a-Billy must have an original 6-cyl radiator....It's small and narrow, and has a single arm mount on top. Is it in fact a 6-cyl radiator ??
It run nice and cool with the funky 4-blade fan with the stock 350...not sure what will happen after, with the few mods done to it.
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-17-2007, 10:42 PM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thats a darn good price for an aluminum radiator....cheaper than you can usually get a standard new V-8 Radiator....I use Summit alot
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-18-2007, 05:42 AM   #10
hewlett2002000
that is a good deal on that radiator. i hope it dident screw up my heads. i dont think it did though. im gonna try this radiator and see what happens. and im just gonna replace the water pump. as cheap as they are i might as well do it. thanks for the help yall, ill let ya know how it goes.
Respect:
Old 03-18-2007, 09:41 AM   #11
Chevy Fleetside
Summits universals don't have tranny coolers in them.. Seeing I am running an automatic I need the cooler... I will be running a radiator and a seperate cooler with fan in my truck...
