Neighborhood Pickle Slinger
Anybody have a picture of a Spring comressor?
Iīm getting ready to take my front suspension apart and need a spring compressor. I read in another topic about just lifting the lower arm with a floorjack.
I personally donīt like the idea doing it that way. At an auction place on the net I found one but Iīm not sure if it will work. Does anybody have a picture of a compressor that will work? Thanks!
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
its all about the +6 inches
Re: Anybody have a picture of a Spring comressor?
You don't need a compressor at all.
Spring compressors are needed for the Mc Pherson strut, which has been up front of 95% of the cars built since the early 80's... with all the injurys from njot using the tool on those, everryone gets scared and says you need a compressor for everything from suspention to hood springs. (I heard some one comment on "all the storred energy on a hood spring. ![]() I do this day in and doy out at work, I had the complete front suspention apart on a 99 C/3500 today... no spring tool in sight. IN all reality, even without the jack, the spring will have more energy from bouncing off the floor than from the A arms compressing it. |
Cantankerous Geezer
Longhorn man is right. BUt if you want to be on the safe side, run a chain thru the spring before you undo it.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
I agree with the above post... just hit it with a hammer and run like hell! Kidding. It's not a big deal, but to be safe run a rope through the center of the A arms to contain the spring and you will be just fine. If your truck is lowered, the spring will just fall right out when the ball joint lets go. It's the same for putting it back together.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
I guess I forgot to add this: Does it make any difference if the truck is together or not?
I have the front of the truck stripped right now. The only thing that is on the frame in the front is the suspension and steering column. Iīd hate to die getting hit by a spring from my own truck. Before I start I will write a note that sais: "My Son gets the truck and tools, all the other stuff my wife can keep."
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 Last edited by blukangoo; 03-12-2007 at 05:49 PM. |
Son of a gun
I hate to be the voice of dissention here (not really, I am always the voice of dissention) I'd much rather you use a spring compressor. It is not one like longhorn is talking about though. It goes through the hole in the lower control arm below the spring, then a threaded rod is screwed into it, a base put below the lower control arm, and the spring is compressed against the lower control arm. Simple and safe. I used mine on two different trucks this weekend, works sliker'n hog snot.
THis is a rough (very rough) scetch of the one I have (I'm not close to my shop) ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
With your truck stripped down like it is, you will need a compressor. There won't be enough weight on the front of the frame. Fully assembled though, compressor not needed.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 03-12-2007 at 06:08 PM. |
@Bus Ted Knuckle:
Thanks for the picture! Almost what I thought of too. Your a Paint professional! @Tx Firefighter: Thatīs exactly what I was thinking. @Longhorn Man: I think if I had done it before I wouldnīt be scared. Because this is the first time I am doing this I want to do it right and not get killed doing it. @whatnow123: I have 14 different hammers, which one should I use? ![]()
The lack of an engine would make it tough to put together without the tool. Tx is right on that.
Son of a gun
GEARHEAD
Bus Ted Knuckle it's not gonna rust is it? Added note ya never know when a PO might have jammed in a longer than should have been used coil. It's a good idea to use some sort of safty precation.
Son of a gun
har... har...
GEARHEAD
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! ![]() Last edited by RACINJASON22; 03-13-2007 at 12:23 AM. |
@Bus Ted Knuckle: Great pictures, thanks for taking them for me. They donīt look too much different than your painting.
@All the others: Thanks for all of your information. I think I will go ahead and get the one I found at ebay. Here is what the Compressor looks like that I will get and what my truck looks like right now.
#15 |
Rally Wheel Club
Is it difficult t find chevy parts in Germany? I would think so, looks like your on your way though good luck to ya
#16 |
@TRUCKER-TRUCKIN':
Engine and drivetrain parts I can get over here. Parts like light lenses und body mounting kits I have to order from the states. The wood for the bed I almost get for free, I work in a big carpenter shop. I will just have to catch the boss on a good day. As soon as I get the compressor I will come back and let ya all know how it went. If I donīt answer in the next couple of months I guess you will all know it didnīt work right.
#17 |
I borrowed this picture of a member`s spring compressor:
#18 |
Too bad Iīm taking the front ones out but I will remember the tip when I get to the back ones.
#19 |
Wish I would have seen this post earlier. You can rent them from your local advance or autozone. You have to put down a $50 deposit, but you get it all back when you return it. This is what I did for my truck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#20 |
I think if I was in the USA I would probably do that but the shops over here either donīt know what the heck your talking about or they donīt lend thier tools out.
Thanks for the tip anyways.
#21 |
Oops, my bad, didn't even notice that!
#22 |
Well, I went to the shop today to find something to work on til my spring compressor shows up. I cleaned my exhaust manifolds and started on my flywheel. I stopped real quick with the cleaning when I noticed it was cracked. Sh*t!
I was so mad that I went and grabbed the floorjack and did what some of the people here said. I didnīt think it would work but it did. Sorry I didnīt accept the tips right away but I just have big respect for things under pressure. Put the jack under the truck, loosen the U-Bolts and let the jack back down. The spring falls out. Damn that was easy. I think itīs not going to be so easy putting them back in but I guess I will see when I get there. Thanks for all the tips everybody and thanks the most to Bus Ted Knuckle for the painting and pictures!
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 Last edited by blukangoo; 03-18-2007 at 03:46 AM. Reason: Forgot to thank yaīall |
