Old 03-17-2007, 03:35 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Front Coli Springs....help!
I found where my front end is clunking everytime I flex the suspension. The drivers side coil spring is not centered in the holes and hits the upper control arm causing the clunk. The PO installed ECE's 2/4 drop and I don't know if it was in fact done correctly. Both springs end at different positions in the lower control arm. It doesn't look like there is any kind of stops to keep them from turning? Is something missing? I did a search but found no pics. Neither of my manuals give a good look at it either. The drivers side also sits about a inch lower in the front if that means anything. Any pics or info would help a lot! TIA.....
Damn...should have checked my spelin in the title!
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 03-17-2007, 03:45 PM   #2
SCOTI
SCOTI's Avatar
Re: Front Coli Springs....help!
The lower control arms have a small 'divot' formed in them to seat the tail end of the coil. This keeps the coils in similar positions from side to side.
Verify that both springs have the tail end of the coil-winding seated in these divots.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-17-2007, 04:08 PM   #3
cdowns
cdowns's Avatar
if i were you i'd take both springs out and compare them to make sure you in fact have a pair of springs that match
Old 03-17-2007, 04:49 PM   #4
Draggn66
Draggn66's Avatar
I've already got the lower balljoints loose and the shocks removed. All I should have to remove is the sway bar mounts and the springs should come out....right?
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 03-17-2007, 05:07 PM   #5
cdowns
cdowns's Avatar
yes just lower the control arm and it'll slip right out
Old 03-17-2007, 05:14 PM   #6
Draggn66
Draggn66's Avatar
Thanks for the input guys.
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 03-17-2007, 05:18 PM   #7
dan468
dan468's Avatar
you should check this first before removing them. 99% of the time this is it.
dan468 is offline   Reply With Quote
Old 03-17-2007, 05:44 PM   #8
Draggn66
Draggn66's Avatar
Yea neither spring was in the divot. I loosened everything up and seated the springs correctly and put it all back together. Clunck is gone now but I've still got the lean. Gonna pull the springs and compare them.
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 03-17-2007, 05:48 PM   #9
dan468
dan468's Avatar
When trying to figure out the lean, don't discredit the rear springs, anything in the bed, or properly adjusted caster. Anybody else have any problems with their truck leaning and the cure?
Old 03-17-2007, 05:55 PM   #10
Draggn66
Draggn66's Avatar
The PO put this ECE 2/4 drop on about a year ago so I would think the springs would be ok but ya never know. I put all new tie rods, ball joints and bushings in the front and had the truck aligned so that should be good. Cab mounts and radiator support are all good. Just want's to dip about an inch which in turn makes the right rear a bit higher than the left. I know the new chevys have a lean problem. Maybe they always have?
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 03-17-2007, 07:16 PM   #11
67chevemall
67chevemall's Avatar
sounds like maybe the springs are not tall enough to fill the viod.
Might need taller springs or new ones if they are crushed.
I would go over the whole front end and see whats up
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-17-2007, 07:28 PM   #12
68 P.O.S.
I currently have the same problem with my truck's back end. It turns out my bed doesn't sit right because it's too rusted and there's no real bed wood.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-17-2007, 09:52 PM   #13
67chevemall
Me too. I have 4+ " on the right side and 2" on the left inbetween the top of the tire and the fender.
I've tryied everything, with the levels and bed bushings
I think one of the springs is soft or shorter.
