Old 03-15-2007, 03:53 PM   #1
skeet85silverado
transmission problem
This is the problem i have. I got 1985 chevrolet silverado. I installed a 700r4 transmission out of a 93 suburban. The problem i'm having is that i can't screw my speedo cable in anywhere. It look like a wire is suppose to go in the spot for the speedo cable. If anyone has had this problem can you please help.
skeet85silverado is offline   Reply With Quote
Old 03-15-2007, 04:07 PM   #2
lurch115
lurch115's Avatar
Re: transmission problem
are you sure that it isn't the newer version of the 700r4?? i think its actually called a 4le something or other....can't remember right off hand what it is called...but if you look a little closer there should be some type of clamp holing the electric speedo sensor in where the housing for a speedo gear should be....one out of an older 700r4 might fit, but don't hold me on that...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-15-2007, 04:18 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
yea it hink hes right u might have the electric speedo.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-15-2007, 08:55 PM   #4
bbchevy
87 Wanna Be K30
bbchevy's Avatar
if the transmission is from a 93, its an electronically controlled tranny, called the 4L60E. There is no spot for the speedo cable. And unless you have the computer and stuff from the 93 also, the trans won't work. 700R4's were used up until 92.
-Scott
Was: 1987 V10 Silverado
TBI 350/700R4/208 with 3.42 gears
Is: A wanna be K30
330hp 350/465/205/D60/14FF with 3.73
hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc....
bbchevy is offline   Reply With Quote
Old 03-16-2007, 07:18 AM   #5
skeet85silverado
The transmission it works but i just don't know how fast i'm going.
Old 03-16-2007, 07:41 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
The 4L series trannies had electronic controls inside and out of the tranny. This includes the speedo output. There is a conversion tailpiece for these trannies that is sold by Street and Performance to allow the use of both the electronic and the manual speedo output. It is a little pricey. I am not sure if a conversion to an older tailshft is possible.
Old 03-16-2007, 09:08 AM   #7
skeet85silverado
Do you have there web address?
Old 03-18-2007, 09:59 PM   #8
86k10
Is your electrical plug on the left or right side?
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 03-18-2007, 10:41 PM   #9
piecesparts
http://www.hotrodlane.cc/ Try this...
Old 03-19-2007, 08:47 AM   #10
skeet85silverado
On the left
Old 03-19-2007, 09:27 PM   #11
86k10
At least you don't have a 4l60E, I would just take off the rear housing and pull the electric sensor gear off and put the old style gear on, hopefully there is a hole in the shaft for the retaining clip.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
Old 03-20-2007, 08:27 AM   #12
skeet85silverado
What do i have a 4l60 or a 700r4
Old 03-20-2007, 11:06 PM   #13
86k10
They are the same.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
