efi tank
what tank are you guys running in a 47-54 that supports efi?...more specifically a 500 horse ls6?
No limit has one but they want $440 plus pump plus sending unit.... any ideas? |
Certified Car Nut
Re: efi tank
I'm going to run this one from Summit Racing it cost 249.00. Part number SUM-291220-S. I will fab someway to mount it once I get it.
![]() Last edited by Kabwe; 03-10-2007 at 07:32 PM. |
Re: efi tank
I had a custom one built to fit (20+gal.) with a stock TPI fuel pump. If you go the custom route, use the fuel pump that normally feeds the motor. Shouldn't go wrong there, right?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
Re: efi tank
well im hoping for 100 hp over stock....so Im not sure how that will work....ugh
Re: efi tank
there is a cheaper one from summit, $169 ish, it is plastic.
polishing a turd
Re: efi tank
what kind of pump are you using? in-tank or external? if external, the only thing you would need to do is drill a hole for the return line.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
