Old 03-18-2007, 09:27 PM   #1
NPilot1975
NPilot1975's Avatar
No Rear Brakes with lots of troubleshooting need help!!
OK, I was driving my truck the last 2 weeks as my daily driver. I was suspect of my rear brakes and finally jacked it up this weekend to see if they were working and they weren't. First I tried the obvious and rebled all 4 brakes, with neg results. Then, I used CPP and some comments from the board and tried to reset the combination valve, still no rear brakes. At this point, I am not sure what else to try another than a new master cylinder. Attached below is a photo of my current setup. Is it the right one for disc front and drum rear? Thanx for any help.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-18-2007, 09:53 PM   #2
KFreddy
Active Member
KFreddy's Avatar
Re: No Rear Brakes with lots of troubleshooting need help!!
With disc all around you can ditch the combination valve but you will need to add and use a proporting valve for front/rear bias adjustment...
KFreddy is offline   Reply With Quote
Old 03-19-2007, 10:10 AM   #3
NPilot1975
NPilot1975's Avatar
Is there a way tell if the MC is good without taking it off? I had the lid off, if the brakes were pumped there was a jet of fluid that would come up in each bowl (not out of the bowl but above the surface of the fluid.) I was told this is not good. I get fluid at all four corners, but the front discs work and the rear drums have nothing. I am assuming MC or Combo Valve????
Old 03-19-2007, 07:24 PM   #4
JimKshortstep4x4
I would suggest taking the line to the rear off of the prop valve and try bleeding it there first. If no fluid comes through it is the prop valve or the MC.
To eliminate the prop valveas a problem bleed the rear of the MC only.
All of the Master Cylinders that I have seen have the fluid stream up when depressing the brake pedal.
Sometimes bleeding the rear brakes can take forever so if the MC and prop valve check out, just keep bleeding the rear.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-19-2007, 07:42 PM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
one another thing to think about is the wheel cylenders
goodluck
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-19-2007, 08:49 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you don't have a good stream of brake fluid at the rear wheels(if it dribbles rather than squirts) You could have a collapsed hose on the rear.You may still get some fluid but it may not be enough to actuate the shoes.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-19-2007, 08:51 PM   #7
RANDY COX
RANDY COX's Avatar
Check the rear end rubber line (on the differential) if it's old and drie rotted it will collaps and thus no fluid,will pass through.Hope this helps.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-19-2007, 08:54 PM   #8
RANDY COX
RANDY COX's Avatar
Oops,Paneldeland beat me to it,wouldn't hurt to check.
1964 BBC 402 4x4
Old 03-19-2007, 08:54 PM   #9
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
When I did my rears I didn't just bleed them, I used one of those mityvac pumps and actually flushed all the old fluid and lines out. It took several refills of the master cylinder before the fluid didn't come out black and full of stuff: a good reason for changing the hoses- they rot from the inside too, and they are 30+ years old.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 03-19-2007, 11:40 PM   #10
NPilot1975
NPilot1975's Avatar
Thanx for all the comments. I may try to bleed the back again, although it seems to have pretty good stream when bleeding. I completely rebuilt the rear brakes 5000 miles ago and they look like they haven't been working at all. The shoes still look new. The combo valve is tripped and I can't get it to center, could that indicate a MC problem?
Old 03-20-2007, 05:30 AM   #11
JimKshortstep4x4
Are you saying that you cannot get fluid past the prop valve?
If the valve is tripped and you cannot center it, there may be a leak in the rear. If it is tripped, you can usually get fluid by if you pump the brakes very lightly.
Power bleeding as mentioned is a very good way to go.
Jim
Old 03-20-2007, 02:11 PM   #12
A.P.
Black 72 Chevy
A.P.'s Avatar
NPilot1975
I recently fixed my truck's brake problems and it was similiar like yours. My front brakes would lock easily and the rears would not assist. It turned out to be my prop valve was stuck.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
