Old 03-21-2007, 09:13 PM   #1
jorgensensc
jorgensensc's Avatar
Question on rear axles...
The truck I just got from a fellow board member (70 rs/ss) has front crossmember conversion off a 73-87 truck.. so 5 lug. The rear is a 6 lug off a '68 I think. (truck is a '68, but the rear axle isn't original, had 3.08s, he changed to 3.73s)
First qustion. What is the length from flange to flange on the pre 71 rear, and what is the length on the 71 and 72s? I would like to measure to make sure I know what rear I have. Did 71s and 72s have 6 lug coil spring in the 3/4 tons?
Second Question. Can I get the original axles redrilled for 5 lug? Or should I just spend the money on new axles.If so who has good prices? Money is kinda tight, and 70 rs/ss is going to send me some rallyes so he can get his tires and rims back that are on the truck now. They go to a couple of other projects he has, he just wanted to make sure that I had good tires for the drive home (what a guy!)
I will get pics as soon as I can! I know y'all want to see. I can say that the 1400 mile trip went off without a hitch. And I got about 14 mpg going 75-85 the whole way. Damn 2 barrels are cool!!
Thanks guys!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-21-2007, 09:33 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Question on rear axles...
71-72 were all 5 lug on 1/2 ton and 8 lug on 3/4 tons.
If you have a 6 lug coil rear in it now, it's a 70 or earlier rear 1/2 ton.
You can either get a 71-72 rear, order special conversion axles (ECE has em) or convert a 73-87 rear to work. I prefer the 73-87 rear myself. You have to weld new saddles on it and use a super track bar, but that's all easy.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-21-2007, 09:56 PM   #3
jorgensensc
THanks for the reply Kevin. So redrilling the originals is out of the question?
Old 03-21-2007, 10:09 PM   #4
neonlarry
neonlarry's Avatar
Rear Axle Measurements
MEASURED ACROSS WHEEL MOUNTING SURFACE
60-61" 64-69 1/2 ton 2wd Chevy/ Some GMC 6 lug rear end 12 bolt Coil spring set up
62" 70 2wd 6 lug rear end 12 bolt
71- Newer 2wd trucks use a 5 on 5 lug pattern
You can have yours redrilled, IIRC you will have to have at least one hole welded to do this.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-21-2007, 10:11 PM   #5
Robznob11
Robznob11's Avatar
got mine from moser for 280.00 shipped and they are non tapered 40% stronger than origanals, im not positive but i think that 70 1/2 trucks had 6 lugs but were the wider rear like in the 71-72 you might ask around...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
