Old 03-18-2007, 03:12 AM   #1
st1
st1's Avatar
will it fit???
I want to know if a 69 frontclip will fit on my 79 gmc? I am having the truck built in North Carolina while I am stationed in Hawaii.
stone sends...
78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201)
06 Dodge Charger Daytona R/T
05 Suzuki GSX-R 1000
st1 is offline   Reply With Quote
Old 03-18-2007, 03:31 AM   #2
bigtruck81
Re: will it fit???
define "front clip" if you're referring to the front sheetmetal, no way. if you're referring to the suspension crossmember and related components, its nearly bolt up, but why would you want to go back to drum brakes?
bigtruck81 is offline   Reply With Quote
Old 03-21-2007, 11:25 PM   #3
st1
st1's Avatar
Re: will it fit???
Thanks for the reply. I did not think it would (front clip sheetmetal that is) but just had to ask. My truck is in NC and I am in Hawaii so I just cant go to the junk yard and take a part home, you know.
stone sends...
Old 03-22-2007, 12:38 AM   #4
Russell
Professional Grade
Russell's Avatar
Re: will it fit???
Yeah, you'll need sheet metal from 73-80 to bolt on
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
