That Guy
Re: 1978 Scottsdale Stepside..New Here.
Yea but it has a bunch of other parts like.......
![]() That is pretty much the kit itself.
Cruzzzn' Vet
The 2 bottom "U" saddles mount under the axle and into the bottom of the spring perches, make sure you put them in with the 2 small holes Forward as this will pull the drive shaft out enough from the tranny to prevent binding, the 2 top brackets are your shock extenders, which you would bolt on to the shock mounts on the axle, mount the 2 red bump stops on the frame directly above the axle to prevent your axle from bottoming out on the frame. Pretty easy. search the site for pics as i've seen a few with pics of the setup
![]() John |
