Old 03-20-2007, 06:00 PM   #1
HOGDADDY
HOGDADDY's Avatar
4 row radiator
Well after looking for a copper/brass radiator (3 or 4 row) and even ordering what i thoght was a 4 row instead it was also plastic/aluminum and just when i i was ready to get refund parts guy says LIFETIME WARRANTY??? Hmm let me re-think the situation here:
the 4 row plastic/alloy has in reality 2 big rows that are as wide as old 4 row
i bet it cools better than copper/brass
no solder joints to come loose
its lighter
lmc sells repro BB shroud
and the kicker Lifetime warranty wth have i got to lose?
HOGDADDY is offline   Reply With Quote
Old 03-20-2007, 07:55 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: 4 row radiator
If you go to a parts store and tell them you have a 86 C10, the only radiators that will come up are the small ones. Being that most of the people behind the counters aren't 73-87 fans, they probably wont know what you are talking about when you say 4 core.
The trick I used is to ask them to pull up a radiator for a 1 ton crew cab with a 454. That should bring up the part number for a 4 core radiator. Make sure you take it out of the box first and check that it's the right one though. It's actually the same price as a smaller radiator, at least at Advance Auto Parts where I got mine.
The aluminum one cant hurt though. Long as it's a quality piece. Though a lifetime warranty is nice, if my coolant is all over the road and I'm stranded somewhere the lifetime warranty isn't helping.
Pyrotechnic is offline   Reply With Quote
Old 03-20-2007, 08:01 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: 4 row radiator
I guess it would work fine i have a 3 row but my friend has a 4 and have been looking forward to get it.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-20-2007, 10:54 PM   #4
HOGDADDY
HOGDADDY's Avatar
Re: 4 row radiator
It seems that the copper/brass radiators are being phased out altogether.
I personally have no problem using the alloy/plastic as my 97 silverado had one stock amd it lasted over 100,000 miles before the cracks started appearing in the plastic tank on drivers side.
I got mine at Advance auto too and looked up the BB application and the large alluminum replaces 4 core
There is still a smaller plastic/alluminum one thats cheaper.
Old 03-21-2007, 12:32 AM   #5
Pyrotechnic
Re: 4 row radiator
Guess I might be getting an aluminum one when I do my engine swap for the 2nd time ?
I bought the regular 4 core radiator last summer at Advance Auto. Then with about 300 miles on the new engine and new radiator, someone swerved into my lane and hit me head on so the radiator is most likely garbage now. The A/C condenser took most of the hit and I haven't gotten a chance to take the truck apart and clear the wreckage but I'm pretty sure the radiator is one for the trash pile. Hoping to get that done this summer and swap the engine into another truck.
I got no problem with the aluminum/plastic tank thing. As long as they are quality pieces and at least as good at what comes from the factory in newer trucks, I wont complain. Should save a little weight too. Didn't know you got that from Advance Auto though, I thought it was some generic aftermarket thing at first.
Old 03-21-2007, 10:10 AM   #6
boatpuller
boatpuller's Avatar
Re: 4 row radiator
when i bought my new one last year.i went with the original 4 row radiator,mine was a diesel.so that's what i bought.trans cooler lines are on wrong side.diesel lines crossed to drivers side,i changed it.tell them you got a diesel.then maybe they can look it up.i like going to a radiator place,they know what there talking about.and their really not that much more.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-21-2007, 01:09 PM   #7
84slopwaggin
84slopwaggin's Avatar
Re: 4 row radiator
I bought mine from a radiator shop, so they knew exactly what I wanted.
85 LWB Chevy 350/350stocker with Hooker headers dual Magnaflow mufflers upgraded rearend with Eaton Posi unit with 3.42 gears needs interior work(now my DD)
96 Silverado Xcab mild drop(SOLD).
84slopwaggin is offline   Reply With Quote
Old 03-21-2007, 04:39 PM   #8
HOGDADDY
HOGDADDY's Avatar
Re: 4 row radiator
The one at Advance is a Proliance (modine) brand "hencho in mexico" and after some thought I think the big aluminum/plastic tanks radiator is better than the copper/brass.
I just picked-up the BB upper radiator mount and all 4 rubbers at GM for a steal and it fits well.
Old 03-22-2007, 03:00 AM   #9
84slopwaggin
Re: 4 row radiator
So did the original fan shroud work? I already have the larger rubber and the upper bracket should be in friday.
Old 03-22-2007, 06:29 AM   #10
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: 4 row radiator
Check this place out Guys; http://www.radiatorbarn.com/
I have bought two from this place for my car and van, They look and fit like factory and in my case's were HALF the price of my local NAPA and radiator repair shop.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-22-2007, 11:23 PM   #11
HOGDADDY
HOGDADDY's Avatar
Re: 4 row radiator
I went ahead and ordered the BB shroud from (still waiting) LMC to be on safe side I haven't installed radiator im truck yet was trial fitting other parts.
I will let ya know how repop shroud fits. I don't think the other shroud will fit to be honest but am not positive.
Old 03-23-2007, 03:16 AM   #12
84slopwaggin
Re: 4 row radiator
The BB shroud is shorter I guess to clear the accessories. When I order my upper bracket from Classic Parts the guy recommended the shroud that came with truck originally for the 81-87 305-350 ck5,10,20 w/AC. I already have that one so I just ordered the bracket. I've seen pics of the BB shrould used with a SBC engine and the fan just met the shroud even with a spacer being used. I believe the fan is suppose to be just inside the shroud. If I can find the pic I'll post it.
Old 03-23-2007, 03:54 AM   #13
84slopwaggin
Re: 4 row radiator
Take a look at the fan setup on the page. Click on the pics to enlarge them.
http://cgi.ebay.com/ebaymotors/1983-...QQcmdZViewItem
Old 03-26-2007, 11:02 PM   #14
HOGDADDY
HOGDADDY's Avatar
Re: 4 row radiator
I wonder if a longer spacer will put it right? I got the BB shroud it looks really nice and mates up with the upper bb bracket.
I wont know how well it fits until I do cam swap and replace rear seal so I gonna pull motor out real kwik.
In that e-bay pic there is no clutch only flex fan so maybe stock clutch fan setup will work ok.
Old 03-27-2007, 01:28 PM   #15
martinkh
Re: 4 row radiator
Just go to your local radiator shop, they fix'em and they stock common replacements. They know what a 4 core is. It is really just a big block radiator. I put one in a '71 El Camino once, and then in a '77, and the 1970 I just bought has one already (it would have been on top of the list to get one otw). The trans cooler in these is bigger than stock too, so you really don't need a tranny cooler and the risk that comes with them in this case, unless you have a huge cam, slippy converter, and like to race from stop lights to stop lights in 100 degree weather.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
