Old 03-24-2007, 09:21 PM   #1
SSC's76
No No
SSC's76's Avatar
Progress pics BB swap.
Here are some pics. I built the engine last weekend but had time today to do somthing about it. The hear stuff is done. The headers are in and connected, the starter is in carb and linkage on. I just need to put the radiator and distributor in and I can fire it on carb cleaner just for kicks. I need to wire in the electric fuel pump and find a BBC POWER STEERING SETUP! Appears they are different and the one I thought would work isnt for a BB either.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-25-2007, 12:00 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Progress pics BB swap.
looks cool. When you get her runnin you should back a little sound recording id like to hear her run.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-25-2007, 12:06 AM   #3
bigblock73
yeller
bigblock73's Avatar
Alan Grove has everything you need (except for maybe the pump) for your BB power steering needs. I got ALL my brackets from them...SUPER happy with 'em!
bigblock73 is offline   Reply With Quote
Old 03-25-2007, 08:06 AM   #4
grinch4om
dang its hot
grinch4om's Avatar
is that a fresh motor? flat tappet cam? do not fire it on carb clean! follow the cam instructions and let it run at 2000 up for 20 min or what ever the manufacturer says! flat cam will ensue! if it is a roller, disregard this
grinch4om is offline   Reply With Quote
Old 03-25-2007, 11:10 AM   #5
SSC's76
No No
SSC's76's Avatar
Yep freshly rebuilt engine, roller HO GM crate cam. None of the topside pics came out becasue my camera sucks. I'll swing by the shop today and take a few more, hopefully better pics. I'd like to go in right now but I'm waiting for a call so I can go take my motorcycle liscence test.
Old 03-25-2007, 11:14 AM   #6
SSC's76
No No
SSC's76's Avatar
Link with some of the rebuild pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=229914
