Old 03-27-2007, 08:29 AM   #1
spdrcr29
spdrcr29's Avatar
A/C questions
Does anyone know any sites that show schematics for a/c vacuum and controls?
I just redid my dash, and now the heater, fan, and the a/c work, but I can't seem to get the vents switched from the a/c vents to the defroster, and all the cables are attached. I did notice there is a vacuum selector attached to to the top lever on the a/c control, and someone apparently cut and plugged the line on the left as you look at the control. Is this my problem, and if so, where does the line connect?
spdrcr29 is offline   Reply With Quote
Old 03-27-2007, 08:45 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: A/C questions
Heres some pics that might help to answer your Q's
http://67-72chevytrucks.com/vboard/s...d.php?t=225592
sneakysnake is offline   Reply With Quote
Old 03-27-2007, 03:23 PM   #3
neonlarry
neonlarry's Avatar
Re: A/C questions
More than likely the flapper valve in the distribution box is broken. They can be fixed with some fabricated metal strips and/or some fiberglass (recommended) or but a new one ($$).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-27-2007, 03:47 PM   #4
jhow66
jhow66's Avatar
Re: A/C questions
See if this helps:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-27-2007, 06:05 PM   #5
spdrcr29
spdrcr29's Avatar
Re: A/C questions
Thanks for the help guys!
I got the inside/outside vent thing figured out at the vacuum switch, but the flapper must be broke, too, because it stays on the a/c vents. Oh well, it's a summer truck. I'll tear into the heater distribution assembly another day.
Any idea on how much dissassembly is required?
And, while we're on the a/c topic, what kind of money am I looking at to get it recharged. I know the o-rings/seals are good because it still has pressure, but it's not very cold anymore. A friend told me that if it was converted to 134 (?) it should be tagged. Since it doesn't denote being changed to the new refrigerant, he's assuming it's still got the r-12 in it. Suggestions?
Old 03-27-2007, 09:09 PM   #6
spdrcr29
spdrcr29's Avatar
Re: A/C questions
After scouring the web and this forum, I'm thinking of Freeze 12 because it can supposedly be dropped in right over the R-12. It's either that or running it down to the local shop and having them do the Hotshot 414b, cuz my compressor is fine and I'm hearing the R-134 conversion is a pain......
Anybody had any luck with either the Freeze 12 or the Hotshot????
Old 03-27-2007, 10:08 PM   #7
onetonk5
Cereal Killer
onetonk5's Avatar
Re: A/C questions
my 134 conversion blows 37 out the vents in just about any weather...what more could you want?
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 03-28-2007, 09:03 AM   #8
sneakysnake
Re: A/C questions
[QUOTE=Anybody had any luck with either the Freeze 12 or the Hotshot????[/QUOTE]
Ive used both, in auto and in refrigeration. Seems to work pretty well.They are a blend and have to be charged as a liquid so watch slugging the compressor.
