#1 | |||
Union Electrician
I need to know if 5.5" back spacing on a 17" rim is too much for out trucks?I think the rear would be fine,but I am worried about the front and have found a smokin deal on some wheels, but do not know if they will work or not... TIA...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#2 | |||
Union Electrician
Re: back spacing question
ttt
Watch out for your cornhole !
![]() Join Date: Jun 2003
Here's what I know...
a 17x8 with 5 inch backspace works on a lowered truck. In the back, the tires are 275/60/17, which is quite wide and they clear the bed fine. With the extra 1/2 of b.s. you'd want to run a tire that didn't bulge off the rim too much or it would rub for sure.
![]() Join Date: Oct 2005
My first thought would be that is too much positive offset (assuming 8" wide wheel). you're only going to have 2.5 inches on the other side of the rim. Might look a little funny with it tucked that far into the wheel well.
How wide are the wheels you are looking at.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread Last edited by SactoJim; 03-26-2007 at 07:19 PM. |
![]() Join Date: May 2005
Byrd,
Is it a stepside or a fleetside? There is a difference, ask me how I know. Also, rearends from 67 to 70 are not the same width as the 71 - 72s. On the front, I'm using 4.5" back space with 255/60R17 and they fit perfect. Here's a shot from the back with 5" B.S. and 285/60R17s on a 9.5" wide rim I'd say 5.5" would fit better with no chance of rubbing, but real close to the inside of the box. That being said, a 5" back space on a 71-72 fleetside would fit perfectly. ![]() Pete Last edited by Shock_Me; 03-26-2007 at 07:32 PM. |
#6 | ||||
Union Electrician
Yes they are 8" wide
#7 | ||||
Union Electrician
67 fleetside, but it has a 71-2 rear end.
#8 | |
So do you have a ealier rear end or is it the later wider rear axle?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
It's a 71 rear axle. Right now if the truck bottomed out, the tires would probably rub. We will probably change the back rims to a 5.5" backspace to avoid this.
#10 | |
I wish there was a store around here to "try on different set ups" I am going to try 18" rims with the 275/35/R18 Dunlops sp sport8080E I guess 4.5-5 BS no sure yet. ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
