Old 03-13-2007, 06:17 PM   #1
1tonblaze
1tonblaze's Avatar
blazer 1/4 panel questions
ok i got a very good used short bed fleet side bedside for a very cheep price . i have been told that you can take one of these bed sides and cut it down to make a 1/4 panel for a blazer . i was wondering if anyone has any pics or tips to do this . i have a pretty good idea how to do it but i was wondering what every one else has done and how it worked out for them . i am not afraid of doing to much work becuase i want it to look good and to hold up just building a very nice truck to drive around in .
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires
1972 nova plane jane 6 clyinder might sell might keep dont know
2004 chevy s-10 crewcab zr5 sold
1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me
2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went .
1999 k1500 suburban 350 vortec 4l60e leather land yacht .
1tonblaze is offline   Reply With Quote
Old 03-13-2007, 09:42 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: blazer 1/4 panel questions
I haven't done it, but like you said it can be done, ttt for ya
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-14-2007, 06:18 PM   #3
onetonk5
Cereal Killer
onetonk5's Avatar
I bought a set of lifts springs from a guy that had replaced one of his bedsides with a shortbed panel.....looked killer to me....no idea how he dealt with the b pillar area.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 03-14-2007, 09:01 PM   #4
1tonblaze
1tonblaze's Avatar
yeah that is what i am wondering about is the b pillar area . just by looking at it i got a good idea i am just wondering how some one else has done this.
Old 03-16-2007, 08:58 PM   #5
Huck
Huck's Avatar
The B pillar would be a killer unless you can salvage the original and weld it into the new bedside. I watched a body shop to outer skin replacement on some cars and instead of doing the whole section including the wrap around the b pillar, they cut it about 1" shy and welded it there. They explained that it is much easier and stronger to do it that way--easier to hide the welded seam---never thought about it till I saw it done and they are right!!
Huck is offline   Reply With Quote
Old 03-17-2007, 02:28 AM   #6
Rokcrln
Rokcrln's Avatar
As mentioned above cut your old panel about 1 1/2" from the door edge. Then what I would do is drill out all the spot welds from your old outer skin and remove it leaving the inner structure on the vehical. Then do the same for the truck SWB side. This will give you a good point to start for your alignment. Make sure the new panel over laps the door opening then take a .035" cut off wheel and slice right up the over lap thru both panels leaving a perfect gap for welding it up. Then spot weld it back into place and you are ready for filler and paint.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-17-2007, 09:51 AM   #7
1tonblaze
1tonblaze's Avatar
ok that seems easy enough . i just was gettin ideas on the way everyone else has done it
Old 03-26-2007, 10:00 PM   #8
Nobby
Nobby's Avatar
here's what I did and it worked great but I don't have a final pic.
Nobby is offline   Reply With Quote
Old 03-27-2007, 05:55 AM   #9
jaros44sr
jaros44sr's Avatar
Nice work Nobby, any pics of it when finished? I don't think I could take mine that far apart. How come it has a low hump over the trans. or did you put that in. You are talented!! J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-27-2007, 07:11 AM   #10
Rokcrln
Rokcrln's Avatar
Nobby~ Looks good, the only thing I plan on doing different is taking the panel all the way over the top so to avoid the top weld seam you are going to have since you can't get in their to work the welds. I assume you did it this way because you needed your top on to keep the floor section from moving?
Yes we want more pic's!
Kevin
LFD Inc.
Old 03-27-2007, 05:18 PM   #11
jaros44sr
jaros44sr's Avatar
Hey Kevin, What do you mean work the welds, hammer and dolly? D@mn, I knew I forgot something, if this what your saying. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 03-27-2007, 07:58 PM   #12
Nobby
Nobby's Avatar
I'll get some pics soon,I'm to busy at work to get by the shop.Kevin,my metal work looks like Ray Charles did it compared to what you are able to do.It really started out as an experiment and ended up coming out nice. I crimped the panel in on the body and out on the panel,then punched holes in the panel and got to welding.
Old 03-27-2007, 08:05 PM   #13
Nobby
Nobby's Avatar
Hey Jaros44,The floor was shot and I'm putting this body on a 2-wheel drive frame so I'm welding in a good truck floor I had.
Old 03-28-2007, 05:36 AM   #14
jaros44sr
jaros44sr's Avatar
Thanks for explainin', that makes sense. Nice idea on the flange, that should be nice and strong. Easy to work with, as well.... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 03-28-2007, 02:48 PM   #15
Big J
Its lookin' like a Blazer!
Big J's Avatar
Thats what I'm needing to do..... Can't wait to see more progress pics....
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 03-28-2007, 06:10 PM   #16
1tonblaze
1tonblaze's Avatar
ok that pic helps out alot give me a good idea where to start
