Fuel smell in cab
Ok, so I just brought home my 71 that's been in storage for the winter.... I've put all of about 200 miles on it since I've owned it, and today, when I opened the door, I got a good wiff of gasoline, and it lingered for a while. It happened again tonight after work, too, but not as strong. The truck sat outside in direct sunlight, and it had about a half tank of gas..... There are no evident leaks, drips, etc., just fumes. What gives?
Oh, it does have the rubber hose on the filler neck..... Maybe the wrong gas cap? |
![]() Join Date: Oct 2006
Re: Fuel smell in cab
My guess would be the seal,filler neck,or the gas cap
mines smells like gas now and then and as far as i know its just normal
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
![]() Last edited by 1969k10stepside; 03-20-2007 at 11:39 PM. |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
It's just a normal thing when you have a tank in the cab. I've had 5 of these and at one time or another they have all done that.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
![]() Join Date: Feb 2007
It's not normal to have a gas smell in the cab, they wouldn't have sold them that way. You need to follow your filler hoses, fuel lines, and maybe take a look at your tank seams. If you smell it inside your cab, you have a leak somewhere. Most old trucks smell like old upholstery material rather than gasoline.
I like pigs. Dogs look up to us. Cats look down on us. Pigs treat us as equals. -Sir Winston Churchill |
KEEP ON TRUCKIN'
Every old truck I have been in (which is a bunch) that has a tank in the cab has had an occasional gas smell. A hot cab from sitting in the sun, a full tank, a clogged vent tube line,a wore out seal or a number of other things can cause it to happen.
turbo enthusiast
does this mean your not supposed to smoke in the cab? You light your cigarrette and BOOM?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
#9 | |
![]() I would start with the vent line, then i would move to the seal on the sending unit.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
I don't even fill mine up anymore. I never go over 3/4 of a tank in my truck, I notice that anymore and I get the smell.
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some ****in' muscle. -Wooderson From the movie Dazed and Confused |
#11 | |
Now, who sells the gasket between the sending unit and the tank, without buying the entire sending unit? I checked two places' online cats and didn't see it listed seperately. |
Red Headed Step Child
The relocated tank was the best thing I've done to my truck. It's just nice not to have to worry about it anymore. I was changing seals and fixing lines a plenty in my old tank in the cab, I couldn't hardly drive the truck from the gas smell.
"Dinner, the perfect break between work and drunk" -Homer Simpson |
#13 | |
67 is sold
Thats why I bought my truck. Nothing soothes the soul like gasoline vapors.
1969 ![]() ![]() |
#15 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Usually, a new gas cap will fix most gas odors in these trucks. Any parts store that carries Stant brand parts will have one. They're under 10 bucks.
#16 |
Any number of places for that smell, but none of them normal or safe.
The seal around the sending unit, the vent line, the gas cap, the fuel line or its fitting, or like in my case, the tank had a pinhole in the welded repair on the bottom of the tank. If none of these are the culprit, see if the fumes are coming in from the carb then through the firewall. Personally, I'm moving my tank to the rear just to avoid all these problems, regain some much neded interior space, and improve the safety factor should the unthinkable ever happen.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#17 |
don't forget about a little more traction from the weight in the rear, 21 gallons of gas = 132lbs +or- depending on the grade of gas.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#18 |
![]() Join Date: Dec 1999
I chased the gas smell in my cab for six months. Finally replaced the little rubber hose on the filler neck. That was it. Once it was out of the cab I could see it was dry rotted. The crack were really small and no sign of liquid gas seeping out. The crack was just enough to let fumes in the cab. Might try it. Cheap fix.
72 Shortbed fleetside 402 BB, AC, Posi 72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new 66 Chevy Caprice 2 dr 74 Honda CB750 New Palestine, IN |
#19 |
Thanks for the info.... I went to the local parts depot today and grabbed new lines for the vent and evap line, and ordered a new sending unit with lock ring, gasket, and the windsock..... One place wanted a 20 dollar order for a 2 dollar sending unit gasket, and another wanted 13 bucks shipping, so I just said fughedaboutit and bought the whole unit..... I figure these gas lines and sending unit prolly lasted 35 years... They've served there purpose, I'm gutting the interior this weekend to do seat, dash, carpet, instruments, etc, so if the new lines last another 35 years, I'll be happy.
#20 |
My friends 71 reeks of gas like crazy. If you just take a ride in it, you will smell like gas for the rest of the day. Good thing he doesn't smoke?
#21 |
sometimes ill be inside my truck working and all of a sudden i get this wiff of gas then it just goes away like 15 seconds later this happens like every half hour
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
#22 |
I haven't seen a posting about another line in the cab. (Unless this is the evap line mentioned in # 19) I have a 72 which there was a gas line that had something to do with the accumulator under the hood. A gas line ran from the accumulator back to the fuel tank, however, before it ran back to the fuel tank, it went up a "B" post (can't remember if it's driver's or passenger's) did a U-turn near the roof and came back down. That was the problem in mine, it was rotten.
#23 |
I agree that something is probably wrong but mine smells like gas too. I did not find a leak on mine but I assume it is the filler neck or the sending unit gasket. I use my bed tank unless I go on a long trip.
'70 K-20 San Diego, CA |
#24 |
Replaced gas cap, both lines to the vent in the passenger B pillar, evap line on filler neck, and sending unit o-ring.
Total cost---- $18.53 Not worrying about exploding vapors in the cab------ PRICELESS! ![]() |
