Who makes correct bushings for 67~68 core supports???? It seems everybody sells 67~72 but they are not all the same!
![]() I am putting togther a couple 67 & 68's and need to find the correct bushings soon! See link -> http://67-72chevytrucks.com/vboard/s...d.php?t=190626 Does anybody know who has the correct core support bushings kits forsale?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 03-30-2007 at 11:15 AM. |
67 shorty
Re: 67~68 VS 69~72 Core support bushings
You can make your own.The bushing is a 1/4 " rubber washer.
67 SWB with enough parts to build two ![]() |
Questionable
Contact www.gmcpauls.com - I think that's where I bought mine.
69-72 uses a couple of urethane bushings along with a couple of 5/16" 2.5" long carriage bolts and some washers. 67-68 uses two rubber pieces similar to a rag joint with a couple of 5/16" 2.5" long carriage bolts and some washers. I know the 67-68 comes with a special metal piece that you bend down once the bolt is tightened - this keeps the nut from spinning out. You could technically make your own stuff. I have a picture of the setup somewhere around here (GMC Paul's gave it to me), it is very accurate and easy to read, showing what order to stack everything in. Fastenal.com carries the carriage bolt (it's not a normal size you'll find at Ace Hardware). I can get the part # for you if needed. You're better off just to buy the kit.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-30-2007 at 12:37 PM. |
Chad - Cabinent Guy is correct. I think it goes like this:
Core------------- --------- Rubber Washer --------- Flat Washer Frame BRK--------- --------- Flat Washer --------- Rubber Washer --------- Flat Washer --------- Lock Plate The Filling Station in Lebanon , OR carries this specific part #CD-88 for $25.00 in the April 05 catalog. Fits 1960 to 1968 Chev/GMC truck. Let me know what I am supossed to bring to Portland - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
I also have them available at http://s-c-t-p.com/weat.html
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
