Old 03-25-2007, 08:00 PM   #1
hawaiianblue72
hawaiianblue72's Avatar
Backup Lights - 3 on tree to 4 on floor
I'm sure this has been talked about before, but I need help figuring out how to make my backup lights work. My truck has been converted from a three on the tree to a four on the floor and my backup light have never worked. My mechanic suggest a toggle switch set up (not sure about that fix.). Is it possible to get the switch that goes on the tranny and make it work somehow? How hard would it be to rewire one that worked only when it's in reverse? Has anyone else had this problem? How did you fix it?
hawaiianblue72 is offline   Reply With Quote
Old 03-25-2007, 09:11 PM   #2
BurnoutNova
BurnoutNova's Avatar
Re: Backup Lights - 3 on tree to 4 on floor
thats the easiest way to do it... thats what i would do, for what its worth
BurnoutNova is offline   Reply With Quote
Old 03-25-2007, 09:21 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Does the four speed tranny have a switch mounted on it somewhere? A lot of them did over the years. Otherwise look for a place that you can install a momentary pressure switch that the gear shift or a shift pin will actuate.
Old 03-25-2007, 09:26 PM   #4
msgross
msgross's Avatar
My 4 speed has a switch mounted just left and forward of the shifter, under the floor. I think that it's for the lights...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-26-2007, 05:33 AM   #5
JimKshortstep4x4
I hooked up the backup lights on my son's 4 speed and it is very straight forward. I ran the two wires from the switch on the transmission to the bulkhead connector to get the wiring through the firewall. Once the wiring was connected, I picked up the circuits on the inside by using two made up jumper wires. The jumper wires were made with male terminals so it was just a matter of plugging them in to the existing female terminal.
If you want to route the wires directly through the firewall to the existing connector, then that will be easier yet.
His truck was an automatic originally but your three speed should have the female connector as you originally had back up lights as I understand.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-28-2007, 08:45 PM   #6
hawaiianblue72
Hey thanks for the info. Can I get a ticket for not having backup lights?
Old 03-28-2007, 09:55 PM   #7
68caliRat
Need a bigger hammer..
I hope not, my switch has been broken for ten years!
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 03-28-2007, 10:45 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
You could get a ticket, but most cops have better things to do. Only place I would worry was if there's a mandatory safety inspection.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-28-2007, 11:54 PM   #9
pissonNOS
senior member
pissonNOS's Avatar
i had/have the same problem i just left it
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 03-29-2007, 12:11 PM   #10
cbbs02
you could also use a brake light switch an make a mount that sits between the tranny and the floor pan so that the shift lever hits it when reverse is slected.
cbbs02 is offline   Reply With Quote
Old 03-29-2007, 01:28 PM   #11
davidh
davidh's Avatar
What color are the wires that run the back up lights or what does the plug look like? I'd be intrested in getting mine going for my 67 too.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 03-29-2007, 01:32 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
On a stock truck, they are green (both are green, one has a black stripe), they're two wires that are side by side (like how speaker wire looks.) and has a plug with a rubber cover over it that goes to the switch on the tranny. Thats what they looked like on the '72 I recently took the whole underhood harness out of.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-29-2007, 01:50 PM   #13
davidh
davidh's Avatar
Does it come out of the firewall with the rear harness plug then?
Old 03-29-2007, 01:59 PM   #14
67ChevyRedneck
On the one I took off, it was part of the underhood harness (not taillight). The one that bolts to the firewall to the fuse block.
Jesse James
Project "On a Dime"
Old 03-29-2007, 02:12 PM   #15
davidh
davidh's Avatar
What i'm talking about is that plug that runs thte tail lights not at the back of the fuse box where the junction is at. David
Old 03-29-2007, 04:34 PM   #16
Orange
Licensed to Thrill!
Orange's Avatar
I have a question related to this. I'll start a new thread if necessary (don't want to threadjack).
My reverse lights work, but when I am in neutral. So what's up there?
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-29-2007, 09:22 PM   #17
hawaiianblue72
Wow In Neutral. Is it auto or manual. I would think Auto Right?
Old 03-29-2007, 11:21 PM   #18
jimfulco
http://www.parts123.com/parts123/yb....dbf~1EW118OL6~ is a ball switch that you can attach to a bracket and activate with the linkage.
jimfulco is offline   Reply With Quote
Old 03-30-2007, 06:51 PM   #19
piecesparts
Yeah; Neutral---no gear engaged....
Old 03-30-2007, 06:58 PM   #20
Kurt L
Kurt L's Avatar
i have mine hooked up to a toogle switch on my 70.works great.especially when theres someone behind you with their brites on.[scares the heck outa them]
Kurt L is offline   Reply With Quote
Old 03-30-2007, 09:07 PM   #21
Orange
Licensed to Thrill!
Orange's Avatar
Yup - neutral.
It is an auto.
DLB
Old 03-30-2007, 11:49 PM   #22
FLEET72
FLEET72's Avatar
Originally Posted by Orange View Post
Yup - neutral.
It is an auto.
DLB
There is a switch assembly on the column just above the floor, it needs to be adjusted.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-30-2007, 11:54 PM   #23
FLEET72
FLEET72's Avatar
Looks like an SM465 tranny in your truck, switch should be here:
Oscar
'95 Jimmy 4X4
