What is the best way to strip and paint my top?
Hi guys,
I have a 1972 Blazer with a single wall top that somebody painted black at some point. I would like to strip the old paint off and paint it back to white. Any suggestions as to how to strip it? What type of paint should I use to repaint it once it is stripped? I was thinking applyimg the paint with a roller to help keep the stock 'textured' look. Any suggestions would be appreciated. Rod
1987 GMC Suburban 1/2 ton 4x4 (Beater) 1998 GMC Suburban 2500 4x4 1972 Olds 442 Convertible 2006 GMC 2500 Duramax Crew Cab (Sold) 1972 Blazer 4x4 (Sold) |
Can't wait to retire!!
Re: What is the best way to strip and paint my top?
We had my sons corvette media blasted. In my opinion, it is the best way to go. There may be cheaper ways, but blasting does a very thorough job.
Just my 2 cents.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
The LuvShack Garage
There is also a product, forgive me I cannot remember the name, that you
use on it and just hose it off, it will leave the white and just remove black. *VTBLAZER is the one who told me what/where to get it he may chime in.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
If somebody knows the name of that product, it sounds like the stuff I'm looking for. That sounds like if would make short work of my job. Thanks.
Rod
#5 | |
I believe the top is molded in white, then spayed black if that was the option chosen/offered. Hence the white inside without any paint. ![]() The product I told LUV about is a micro scrub, used for finish work and blending. I used it on my top to clean and repaint, it left the original texture intact. I imagine with enough elbow grease a guy could return a top to all white but I was going to paint it black again anyway so I just made sure it was clean. It's a SEM product called 'scuff & clean' and comes as a paste. Part # 38338 |
Nope, mine was white originally, and then painted black. It was not black from the factory. I guess I'll have to sand the whole thing down unless I get the name of the stripper. Oh that souds dirty!!!
Rod
BTW:?
How do I get my side windows out? Any special tricks? Rod
#9 | |
The LuvShack Garage
The LuvShack Garage
OIC, Well mine are hard a brittle, on all 3 of my tops, my bad, mine had to be cut
Scuff and Clean is mostly used on bumper covers and blend panels to insure that panels are completely sanded. It is amazing if it stripped the paint on your top VT. You could also try to use Aircraft stripper "for fiberglass" there are two different types and then blast it off with a pressure washer. That may be easier and faster. Try just a small spot first.
Good luck |
#13 | |
The pics I posted show what it did for my top...kinda interesting that it worked so well. I used it with a scotch brite pad, maybe that's what really took the paint off. LUV, if they were brittle they needed changing anyway, no worries. ![]() Last edited by vtblazer; 03-25-2007 at 05:31 PM. |
#14 | |
Just need a couple more parts.
Rock guard works nicely on the bottom of the truck too where the rocks tend to bounce off it.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
#15 | |
Global warming is a myth
![]() Quote:
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
#16 |
My dad and I painted the top on his 78 Bronco XLT black. It was black from the factory but the white top was showing through in some areas.
We used satin black Rustolium and applied it with a roller since the top had a texture to it. It soaked right in. We used a foam brush for the detail work around the windows. It came out beautiful. I'm a picky SOB too. It worked, looked great, and held up well. I highly recommend it. If I ever put my top back on, I will paint it first with a roller. When washing the top a chalky residue would rinse from the top onto my Blazer when I had the top on. I'm not sure if that was dried powder from the paint or the actual top breaking down.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 04-01-2007 at 10:36 AM. |
#17 |
The LuvShack Garage
Off Topic, Well I washed mine Friday and everytime I went over the top with
soap the water would turn white? It has not appeared to loose it's color, but it is pretty brite now, wonder if the PO could have bleached it at some point?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 04-01-2007 at 08:09 AM. |
#18 |
Same thing here. The water looked like 1% milk when washing the top. I think the paint is pretty much gone. You can't really tell because the top and the paint are both white. Nice Blazer BTW.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 04-01-2007 at 10:38 AM. |
#19 |
The LuvShack Garage
Exactly, oh well I guess the top just needs to come off
#20 |
Yup, that's the best way to handle it. I will paint my top before it goes back on, if it ever does go back on. I'm not into the expossed fiberglass look.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 04-01-2007 at 10:46 AM. |
#21 |
The LuvShack Garage
#22 |
![]() Join Date: Dec 2002
The milky water is the paint breaking down. These tops are to some extent porious. some places take more paint than others. The last time I panted my top was ten plus years ago. Acyrlic enamel laid on heavy. Still slick and shiny on most of the sides Very dry on top That is why the black factory tops fade to white. None of these tops Black or white were very shiny at all when brand new
#23 |
urban fourwheelin
my top bleeds too.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 04-01-2007 at 09:45 PM. |
#24 | |
Photo Gallery of 1972 K/5 Blazer CST |
