Difference between 81-91 Blazer and Suburban Frames
Here's the deal. The previous owner of the 1981 Blazer 2WD that I have now cut a few inches off of the frame to install a "custom" bumper off of a Dodge Truck or something. Now I want to install the original style bumpers back on my Blazer. I have done some research in the LMC catalog and determined that the rear brackets for the bumper are the same. But what I want to know is if the frame at the rear is the same for sure.
Does anybody have any pictures of the rear on a 81-91 Suburban that they could post or email me? Heres some pictures of what they did to my frame rails: http://www.studentweb.eku.edu/aaron_cowan4/DSC01854.JPG http://www.studentweb.eku.edu/aaron_cowan4/DSC01855.JPG |
Re: Difference between 81-91 Blazer and Suburban Frames
Best I can do for you. Hope it helps.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Kevin,
That's a Blazer right? I see a sawzall there...Are you getting ready to cut the frame horns back some? If so I want the frame horns!! |
#4 | |
That contraption on the ground was the home-made tow hitch the PO installed. I installed a nice 2" reciever hitch after that. Unfourtuneatly the PO welded it to the frame behind the horns. You can still see the ends of the angle iron behind the top, inner bumper mount holes. There is no way to put the bolts though those holes now. ![]() I might be able to get you the frame horns from a donor K5 but it will be a while before we get to that point. If you still need them then it would only be shipping cost.
junk collector
Is that a sway control mount on that hitch? I sure hope no one was pulling somthing big enough to require a sway control with that hitch!
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
#6 | |
That would be great. The earlier the better! Thanks for the offer, just let me know when you would be able to get to them. I will pay you for the S&H and for the parts. Aaron |
Slots go on anything!
The suburbans are the same at the rear bumper.
#8 | |
But it looked wrong and I needed a reciever for a bike rack more than a ball to tow with. I don't think I would ever tow anything that big with a Blazer either way.
#9 | |
But neither one of us are in any kind of hurry to get it done. So it will be a while. But I will let you know when that time comes.
