Old 04-02-2007, 08:54 PM   #1
traskins
Need Help Badly
I have a 70 c-10 that the PO changed to disc brakes. The problem is the only numbers I can find are in the hub assembly they turned into a rotor,it is a gm number but I cant seem to be able to find it anywhere the number is 383310 with either 80 or SD at the end I need to replace the wheel bearing and cant.
traskins is offline   Reply With Quote
Old 04-02-2007, 09:00 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Need Help Badly
Have you checked the wheel bearing itself for a part number, or is that number you listed from the wheel bearing?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-02-2007, 09:18 PM   #3
traskins
Re: Need Help Badly
Ya I checked it but there gone on the bearing,that number is from the hub
Old 04-02-2007, 10:41 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Need Help Badly
find a good parts guy, and ask for the P/N for a 71 inner and outer, then an 80 inner and outer, and then an 86 inner and outter.
if my suspicions are right... it's the same.
Old 04-02-2007, 10:52 PM   #5
drman929
drman929's Avatar
Re: Need Help Badly
Or take your bearings to a parts house and find a patient counterperson to match them. I work at a Carquest and thats a normal routine. At the store I work at, there's only about 30 or so sets of bearings and races that are your typical wheel bearings, so it doesn't take that long if you don't have a number to go by.
drman929 is offline   Reply With Quote
