Old 04-01-2007, 02:24 PM   #1
CUSTOM/10
CUSTOM/10's Avatar
TH350/NP205 Complete Set-Up
Recieved this in a recent transaction, But already have a 700R4/NP205 that I'm going to use. So this one's up for sale. PO said that the trany has been gone through, ( I don't know exactly what that means, and have no proof other than these pictures ) From what I see someone has obviously done some work on it. Everything is clean and painted. Inside was also clean other than some paint over spray and the fluide that leaked when I removed the converter was clean. So I have no reason to doubt what I was told.
$500 + shipping ( Would rather not ship for obvious reasons )
I reserve the right to sell this locally !!!!
Oh yes, this was a rolling chassis, projeect that was never completed, so what ever was done to it the has 0 miles since.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-01-2007, 05:44 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: TH350/NP205 Complete Set-Up
One more Pic. It comes with this deep aluminum pan also.
Gary
72 SWB 4x4
My 72 SWB Build
Old 04-01-2007, 07:44 PM   #3
cooters
to bad it has a 2 wheel drive tranny, but the price is still good. To bad you are not closer
cooters is offline   Reply With Quote
Old 04-01-2007, 08:21 PM   #4
1969k10stepside
What makes you think its a 2wd tranny?Im curious...
1969k10stepside is offline   Reply With Quote
Old 04-01-2007, 08:43 PM   #5
FormerMember
Generally, it's the amount of bolt holes that hold the torque converter inspection cover. A "K-case" uses 6 bolts and is generally considered the heavy duty case and uses a cast aluminum cover with struts that go to the engine mounts... A "2wd" case uses 4 sheet metal screws to hold the sheet metal cover on.
I've seen a fair mix of everything, so I can't really conclusively say which is which/
This one certainly looks 4wd to me, as it has a 205 on the back end of it and it's certainly a sweet deal.
FormerMember is offline   Reply With Quote
Old 04-01-2007, 09:04 PM   #6
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Maybe a pickup is different than a Blazer/Jimmy? My '70 Jimmy has 4 bolts holdin on the plastic cover and is absolutely original, and no bracing. 4x4 Blazer and Jimmys were still considered "K" series.
Damm good deal! I wish you were closer also!----DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 04-01-2007, 09:08 PM   #7
FormerMember
Actually they called the K case such because it has a K cast on it.
I think it's actually more of a weight rating. The Th350 and 205 combo I have from a 71 Blazer is the same, 4 sheet metal screws and a sheet metal cover... The 1 ton 73 I took apart is a "K" case.
Old 04-01-2007, 09:42 PM   #8
72swbcamo
Active Member
I PMed you.
72swbcamo is offline   Reply With Quote
Old 04-03-2007, 12:37 AM   #9
Americanrider
mine is from a 72 3/4 ton
Americanrider is offline   Reply With Quote
Old 04-03-2007, 07:53 AM   #10
FormerMember
Eh, how many holes does that have for the torque converter inspection plate?
Looks like 4?
