GEARHEAD
Re: LFD's low buck truck build!
Kevin, on the picture of your U bolt set up with the square tube block, shouldn't the axle tube be welded to the square tube to keep the axle from spinning?
Nice work BTW. I've been learning a lot watching your build threads and was even motivated enough the other day to pull the rusty driver fender off my ride. Need to do some clean up and rust proofing before installing the new one. Then its on to the running bords and floor. Keep pushing us to do more with your positively non-stop ambition. HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#2 | |
Kevin LFD inc. |
