Old 04-05-2007, 12:14 AM   #1
tranz am
tranz am's Avatar
Any reason to swap from 6 lug to 5?
I was just curious if there are any benefits to going to 5 lug rather that keeping the 6 lug. I plan to convert to disk so I have the option?
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-05-2007, 12:15 AM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Any reason to swap from 6 lug to 5?
better choice in wheels is the main reason
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 04-05-2007, 12:17 AM   #3
1969k10stepside
1969k10stepside is offline   Reply With Quote
Old 04-05-2007, 12:25 AM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Ditto
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-05-2007, 12:27 AM   #5
dan42
dan42's Avatar
Yeah. Try finding nice wheels for a 3/4 ton. Not a whole lot of options.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-05-2007, 12:29 AM   #6
cstm68
cstm68's Avatar
im doing it so i can put some 17" or 18" hoppster 550s on mine
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-05-2007, 12:45 AM   #7
tranz am
tranz am's Avatar
looks like 5 lug is the way to go. Where I might find the five lug axles is the question now?
My build thread
1969 GMC SWB
Old 04-05-2007, 12:53 AM   #8
1LoC10
Insert Title Here
1LoC10's Avatar
heres a disc conversion kit
http://www.classicperform.com/Store/...6366RWBK5E.htm
BOBBY
_69 SWB_
Old 04-05-2007, 12:54 AM   #9
short69
short69's Avatar
Everyone pretty much nailed it. I would suggest that you pick out what rims you want first and let them dictate the bolt pattern. I switched to 6 but then all the rims I liked were 5 so now I'm kinda screwed. Also, I dont know a whole lot about the axles but i would think taking a whole one off a 67-70 half ton would be the easiest way unless you feel like taking one apart and taking just the stuff you need.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 04-05-2007, 12:58 AM   #10
cstm68
cstm68's Avatar
i would try summit or lmc truck or brothers
Old 04-05-2007, 01:02 AM   #11
tranz am
tranz am's Avatar
Well I would like to beef up the axle shafts any ways to handle the torque of a 454. I would imagine that jegs or summit may be able to help me there.
My build thread
1969 GMC SWB
Old 04-05-2007, 01:03 AM   #12
tranz am
tranz am's Avatar
do you have the contact info for imc truck?
My build thread
1969 GMC SWB
Old 04-05-2007, 01:09 AM   #13
CG
BlahBlahBlah
I'm doing the disk conversion and keeping 6 lugs. Going to be running stock steel wheels so wheel selection didn't matter to me. I also didn't want the added expense of changing out my rear axles or complete rear end. It all adds up.
Old 04-05-2007, 01:10 AM   #14
tranz am
tranz am's Avatar
I hear ya.
My build thread
1969 GMC SWB
Old 04-05-2007, 01:24 AM   #15
brak
brak's Avatar
5 lug will allow you to easily install rear discs, ie Impala or Camaro calipers, rather than the more expensive Kits.
summit carries 5 lug axles...
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-05-2007, 09:08 AM   #16
lilred67
lilred67's Avatar
cg,i don't know if you have tried it or not but my stock wheels will not go on my 6 lug disc rotors.if i tighten the lugs all the way down the wheel hits the calipers.i'm running aftermarket wheels so it's ok with me,but if i have a flat i hope it's not on the front....
lilred67 is offline   Reply With Quote
Old 04-05-2007, 09:34 AM   #17
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I went with 6-lug rotors, on my C-10, rather than try to find the correct length axles. ...no regrets; drove with 22 lug nuts for far too many years. Also helps maintain the stock appearance of the truck.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 04-05-2007, 10:21 AM   #18
Ole Blue 68
Ole Blue 68's Avatar
I'm in the process of swapping so I maybe be speaking to soon but I would recommend going with a 73-87 swap for three reasons. 1) disc brakes 2) 5 lug 3) cheap a$$ parts. Compare part prices.
CPP is selling 6 lug rotors for $129/pair plus shipping. You can pick up 73-87 rotors at your local parts store for $30 a piece.
Ole Blue 68 is offline   Reply With Quote
Old 04-05-2007, 10:29 AM   #19
martinkh
Oh yes, let's all make our trucks weaker so that they look cooler. If you did have a 3/4 ton (8 lugs), and you were dead set on 5 lug wheels, if it is 4x4, sell it to someone who will use it, and buy a 1/2 ton. Guys wanting to do serious off-roading would appreciate being able to start off with a tougher truck.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 04-05-2007, 11:29 AM   #20
tranz am
tranz am's Avatar
So the 5 lug setup is weaker than the 6? I wouldn't imagine it would be to much of a difference, I mean if you used hardened studs wouldn't it be stronger?
My build thread
1969 GMC SWB
Old 04-05-2007, 11:35 AM   #21
1LoC10
Insert Title Here
1LoC10's Avatar
no, the more lugs you have the more torque it has holding the wheels on..... thats why all the Mustang guys go from 4 to 5.... but as long as your not climping hills and jumping rocks I wouldnt even worry about it
BOBBY
_69 SWB_
Old 04-05-2007, 11:53 AM   #22
67ChevyRedneck
67ChevyRedneck's Avatar
He wants to swap from 6 lug to 5. The 1/2 ton trucks came stock with 5 lugs in 71-72.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-05-2007, 12:02 PM   #23
tranz am
tranz am's Avatar
No. I doubt I will be jumping rocks much. I'm setting this up as a street machine. Not a lifted 4x4 mud jumper.
My build thread
1969 GMC SWB
Old 04-05-2007, 12:14 PM   #24
1LoC10
Insert Title Here
1LoC10's Avatar
5 lugs is plenty to hold it together, maybe going form 8 lugs to 5 might effect something, i dunno
BOBBY
_69 SWB_
Old 04-05-2007, 12:18 PM   #25
bryanw1968
bryanw1968's Avatar
I kept the 6 lug setup when I went to disc in the front. I went with 6 lug ralley's but there are quite a few 6 lug aftermarket options. Not as much as 5 lug though.
bryanw1968 is offline   Reply With Quote
