Rear supsension question
I've done searching on this site and other sites, and I'm trying to make up my mind on rear suspension. I know ultimately it will be my decision, but your feedback would be great.
I originally planned on doing a flip kit on the rear but I soon realized untill I was done buying new shackles, flip kit, new spring, new shocks I would be up around how much a 4 link would run Then I looked into a 4 link that would cost around 700-800 when I was all done I want the truck low/very low and I'm trying to build this truck on a budget. I would also like to eventually put a motor in that would be around 350-400hp Any suggestions on which route to go |
#2 | |
Re: Rear supsension quection
what year of truck are you working on and is it the original rear axle? Are you C-notching your frame? Are you going with stock 15" wheels, 17's, 20's? |
polishing a turd
a flip can be done pretty cheap. it will require a c-notch in the frame.
if you are buying all new parts (springs, shackles, etc.) i guess it could add up to what a 4-bar costs. the 4-bar that most places sell is good for a street truck, but it would likely make the rear squat a lot on launch. that is unless the links converge in side view; then the instant center will determine rear squat or rise. if your springs are in decent shape, just clean and paint them, maybe add a leaf, c-notch it, order one of the flip kits (i think they're $150) and get new shocks. now with that said, i decided to go with a converging offset 3-link
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' Last edited by 1-ton of fun; 04-03-2007 at 09:59 AM. |
It's a 1955 Chevy Step Side Truck
Now it has 14's on it, eventually when its painted It will have 17's on it. I am c notching the rear frame for the axle to have clearance in. I'm deeply considering a triangulated 4 link. ( I have to check on exhaust issues, could just put side pipes on it) The only reason why I mentioned getting new shackles and springs, Is just because the truck is 52 years old, and I'm one of those people, that even know I'm working on a tight budget, I would rather replace the parts now, vs a year or two down the line. Prices I’ve thrown together quick Leaf setup From CPP-479 4 Link 4 link bars---300 coil overs---350 So I guess with out shipping the prices would be 479 vs 650 And the only reason why I was swaying towards 4 link was because I can tune the height up the suspension a better, and if I decide to drop more hp in, I can just buy a heavier spring rate Opinions? |
Hollister Road Co.
This suspension will let you get very low. Its a coil over ladder bar.
I wanted my 53 Suburban low, real low...so I ended up buying a "FatBar" 4-link with air ride from No Limit Engineering.
We did a 6" step notch on the frame, and it's now low! The whole kit was under $1000. Here it is just after we put the motor/trans. in. And those are just junk 14" rollers. It'll have 15x6 Chrome OE steeleis and wide whitewalls. BTW, that is ride height up front, no bags!
![]() Join Date: Feb 2006
That's LOW!!!
Has anyone ever heard of turning stock springs over? Not flipping them from top to the bottom of the axle but leaving them on the top of the axle and just turning them over?? |
polishing a turd
the axle would hit the frame, actually it would not even bolt up like that i don't think...unless you want the axle above the frame
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' Last edited by 1-ton of fun; 04-05-2007 at 09:12 PM. |
tiggerstoy
this whole setup cost me about $50. bucks.....it sit's prity low, holds about 600 pounds in the box before bottoming out on a good bump.
Re: Rear supsension question
tiggerstoy what size tires are you running on the back ? they look like N-50's , thats what i had on mine befoe i wore them out (now 305/60's but i like the N-50s better , they are taller. also what rear are you running?
bfink 55 chevy |
tiggerstoy you said "this whole setup cost me about $50. bucks.....it sit's prity low, holds about 600 pounds in the box before bottoming out on a good bump.
Where can I get a set up like that?? |
Can't see much in the pic. What is your $50 set up? Is it car springs?
could be something like this (in the pic)...mine cost me $70 USD from CPP.
tiggerstoy
yes they are h 50-15's and it looks like ill be geting rid of the rear rim's and tires as soon as i get back to work on the truck.
#15 | |
tiggerstoy
| Bookmarks |
