Drive shaft swap....
So,my 71 didnt have the front driveshaft when I got it and I have a complete driveshaft from another truck and was wondering if it will work on the 71.The truck the d-shaft came off of was a 69 4wd that had a Rockwell T case.And I want it to connect to my 205....So is everything (CV joints,ect) the same,will it all interchange?Are they the same length?
Aluminum slot wheels rule...
Re: Drive shaft swap....
The Rockwell shaft is too short. You'll need to get it re-tubed 2 inches longer if you're going to use it with the 205. Other than that, they are the same and will work.
Hmmm,probably would have to lenghthen it with the lift kit anyways......
