hooking up the neutral safety switch properly...
how do you do it?
I am a Referee of life.
Re: hooking up the neutral safety switch properly...
You gotta give more info.Which column and tranny.What year(I don't think they changed the color code on wire,but....)
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
ok well i hooked it up and it only starts when in neutral and not park. i think its maybe cuz the switch is squished into the firewall...does that make sense?
It's a catastrophic success.
![]() Join Date: Jan 2003
Might check that your linkage on the trans is properly adjusted so that the shifter will will go all the way up into park on the column to trip the switch.
its all about the +6 inches
your column is pushed down too far.
